360 connecting rod #1555082
12/29/13 01:24 PM
12/29/13 01:24 PM
Brodheadsville Pa.
franko Offline OP
franko  Offline OP
Brodheadsville Pa.
Just pulled apart a 5.9 or a 360 whatever.connecting rod turned black from no oil.My question is what happens to the rod when it turns black from the heat? its trash? metal brittle? metal fatigue?
Re: 360 connecting rod [Re: franko] #1555083
12/29/13 03:07 PM
12/29/13 03:07 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Junk
Re: 360 connecting rod [Re: MoparforLife] #1555084
12/29/13 03:44 PM
12/29/13 03:44 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
scrapyard fodder
I am truckless..
Re: 360 connecting rod [Re: franko] #1555085
01/01/14 07:13 PM
01/01/14 07:13 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
yup junk
Re: 360 connecting rod [Re: franko] #1555086
01/01/14 07:37 PM
01/01/14 07:37 PM
Locomotion Offline
Locomotion  Offline
I assume the crank is hurt on that journal as well? How is the rod next to it?
If you plan on replacing it to have a full set to recondition, specify which rod it is. I believe LA 360's and Magnum 360's had different rods. But it should have a casting #.
Re: 360 connecting rod [Re: Locomotion] #1555087
01/02/14 01:58 AM
01/02/14 01:58 AM
dogdays Offline
dogdays  Offline
forging number. only castings have casting numbers.
R.
Re: 360 connecting rod [Re: franko] #1555088
01/02/14 02:06 AM
01/02/14 02:06 AM
woodcrest, CA
magnum440d100 Offline
woodcrest, CA
If ya need some stock 360 rods, I have a set from a 79 with lower mileage. Went with floating wrist pins and going aftermarket rods. You can have these if you want. They're just taking up space
Re: 360 connecting rod [Re: franko] #1555089
01/03/14 12:25 AM
01/03/14 12:25 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
FYI, when a rod gets that hot, 99% of the time the crank bends as well, usually .004-.006 ...so may want to have it checked.
RIP Monte Smith
