Re: How consident shifting without tach ? [Re: OUTLAWD] #1555007
12/30/13 02:11 PM
12/30/13 02:11 PM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
Even though I'm don't spend too much time at the track ( although I'd like to ) , I use a tach. I usually have a full exhaust under the car and sometimes have a hard time hearing my engine when staged next to a dragster of other really loud engine. Back when I had a 4 speed, the first time out, I nearly killed the engine because I think I dumped the clutch in my 440 roadrunner at what I would guess was around 1500-2000 rpm. The next time out was next to a green mustang pro-street, gave it some gas and burned the tires through the first 2 gears . Next run I taped a tack to the steering column..... was much faster on the 3rd pass That was over 20 years ago, now I'd like to get rid of the monster tach ...
67 Dart GT Convertible 273
68 Barracuda 383
68 Roadrunner 383 4spd
1 '01 Ram 2500 4x4 diesel
2 '02 Rams 1500 4x4's 4.7s
3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4
Oh, and a 03 Grand Cherokee and an '00 durango smile
Re: How consident shifting without tach ? [Re: ta3834bbl] #1555008
12/30/13 03:56 PM
12/30/13 03:56 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Actually at the starting line I dont need to hear the eng as I just look at the tach there and come up on the converter to about 2000. Thats about the only time I really use the tach in a normal pass. Sometimes I make myself look at the tach so I can see where I am shifting at. When I raced my 340 Dart four speed I usually only used the tach when launching. I would bring the rpm's up to about 5000 as the tree started and then on the last yellow let the clutch out as the gas pedal went to the floor. I was very consisdent in that low 12 high 11 Dart also. Ran 12.17 three passes in a row one night. To bad I rolled that car but I have to admit I like my 63 better. Ron
Re: How consident shifting without tach ? [Re: ta3834bbl] #1555009
12/30/13 03:58 PM
12/30/13 03:58 PM
IL
furious70 Offline
furious70  Offline
IL
20yrs ago I had a Challenger with a magnum 383, 727, and 3.55's in it. I had big tires on it and didn't have a tach, but it didn't sound like I was going through the traps with much rpm so I tried a pass where I kept it in 2nd through the traps. That did sound more exciting! Got my timeslip and it was within a 1/10th of the time when shifting to drive! I think mph was about the same too.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How consident shifting without tach ? [Re: slantzilla] #1555010
12/30/13 10:30 PM
12/30/13 10:30 PM
Az
Crizila Offline
Crizila  Offline
Az
After a few runs I can usually shift by feel.Made 6 runs within .01 one night on a bike with no tach or light.
That's cause you left it in drive. When you are bracket racing, consistency is everything. I use a shift light. I do set my timing by feel though
Fastest 300
Re: How consident shifting without tach ? [Re: Crizila] #1555011
12/30/13 10:50 PM
12/30/13 10:50 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
put a chip in the msd box with the rpm you shift at, when it stutters ,shift, very simple, after awhile you will shift with no delay. anytime you change something you start over the process. by the way the first shift is the most critical for consistent ets.
Re: How consident shifting without tach ? [Re: Crizila] #1555012
12/31/13 03:13 AM
12/31/13 03:13 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Drive?
Re: How consident shifting without tach ? [Re: slantzilla] #1555013
12/31/13 07:41 PM
12/31/13 07:41 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I rarely use my tach , which is making me think about going to one with a playback mode. That way I can see what rpm`s I`m shifting at and going through the eyes at. Definitely slows the car down to shift (`Glide) into high by the redline .At launch I use my MSD launch RPM module set for 5400 and I can feel where peek torque is and shift there. Works every time .02 consistency !
chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: How consident shifting without tach ? [Re: cudaman1969] #1555014
12/31/13 08:08 PM
12/31/13 08:08 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
That would not work for me as I dont have MSD on my car. I use the MP orange ECU and a Mallory dist. But like I said I just seem to always shift when it feels right to me no matter what I drive. Ron
Re: How consident shifting without tach ? [Re: 383man] #1555015
12/31/13 09:00 PM
12/31/13 09:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I did the same with my max wedge back in the 70s Ron, never could get a tack to work so i just drove it. when i did get one i didn't use it, when i finally did look i was right on 6800 every time. Never even looked at any gauge except in the pits
Re: How consident shifting without tach ? [Re: cudaman1969] #1555016
12/31/13 09:28 PM
12/31/13 09:28 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
So, as I read through this thread, I'm suprised by how many guys don't look at their tach during a run. It begs the question: what are you looking at or paying attention to? (I don't mean this condesendingly, I mean it literally). I can understand that at the top end, you're focusing on the opponent, the stripe and the relationship between the two and yourself. but through the gears, what is occupying your attention?
Now, I realize most of you guys have your hands a little more full than me with my 11 second footbrake street-car. but typically, I'm looking downtrack to keep my line, then when I know I'm getting near the top of the gear, I focus in on the tach to make sure I hit the shifter at the exact moment.
(Sorry to Hi-Jack, Ron. But I think the question is relevent to your post.)
Re: How consident shifting without tach ? [Re: StealthWedge67] #1555017
12/31/13 09:53 PM
12/31/13 09:53 PM
Az
Crizila Offline
Crizila  Offline
Az
Reaction time, Boost gauge, fuel pressure gauge, oil pressure gauge, opponent.
Fastest 300
Re: How consident shifting without tach ? [Re: Crizila] #1555018
12/31/13 10:45 PM
12/31/13 10:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just looking around, listening to the pipes, enjoying the run like a spectator.
Re: How consident shifting without tach ? [Re: cudaman1969] #1555019
01/01/14 12:29 AM
01/01/14 12:29 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I am just looking downtrack feeling the car pull and just shifting when it feels/sounds right. I guess thats why when I see someone ask........what should I shift my combo at...........I think that I would never have to ask that in any car as I just feel that as I wind out whatever I am driving I can tell when its time to shift. I think many racers probably feel the same. Believe me its not to try and sound like I am bragging but as many gearheads will say it just seems like I can tell pretty good about when its time to shift without looking at the tach. But of course I know a good racer shifting with a tach and shift lite will most likely be the most consisdent racer. Ron
Re: How consident shifting without tach ? [Re: 383man] #1555020
01/01/14 12:42 AM
01/01/14 12:42 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Earlier this year I had my daily driver 1990 D150 Ram PU at the track, and it has no tach., I shifted at 60mph into 2nd and 100mph into 3rd and went 12.12 at 109mph 3 times in a row. It had 3.55 gears. Now with 4.10 gears I tried 52mph into 2nd and 90 into 3rd and was between 12.01 and 11.93, with the mph varying between 111.3 and 112.2, on 7 passes. Truck has a 410 sb mopar engine, and weighs 4300 with me in it.
