572 STREET/STRIP HEMI QUESTIONS?
#1554804
12/28/13 05:55 PM
12/28/13 05:55 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
Havent posted here for awhile..but my W8 small block is going byebye..looking to get into something with a lot less maint and hassel at the track but still have some good power.
Looking at building 572 inch Hemi.I want to run E-85 something in the 850 to 900hp range with little street duty.I called Barton and priced the StageV big valve heads and the SR.On the block they recommended the cast world block..they said it was hit and miss on the aluminum.I would rather run the aluminum for the weight savings,but the Indy max block would work just don't know much about them.
Would like to know any thoughts good or bad anybody with similar combos?I am going to run the Barton shaft rockers and his Intake for sure.
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
Re: 572 STREET/STRIP HEMI QUESTIONS?
[Re: FASTFISH420]
#1554811
12/29/13 03:29 AM
12/29/13 03:29 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Tell Ray to hook ya up with a KB block and Millennium heads.
They told me KB blocks are 6 to 8 month wait..and I don't want to go crazy if I was I would get the M head
That's way too long to wait for a stinkin' part.
[Re: racerhog]
#1554813
12/29/13 09:44 AM
12/29/13 09:44 AM
Posts: 1,629 pa
572charger
pa
ive got stage V big valve heads from ray barton and a mopar 2003 steel block roller cam 606 cuin makin 880 -900 hp on pump gas drive it every day !!! i want to go aluminum block soon , block i have is 290 lbs bare !!!!!!!!! lookin at a indy i think KB would be the best choice though maybe ill order it now for 2016 build !!!!!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: 572charger]
#1554814
12/29/13 10:08 AM
12/29/13 10:08 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Go as big as your budget allows. It really doesn't cost any more. My 605 is 10.4-1 and runs on pretty much anything you put in the tank. Heads are a bit small but it still makes 853hp@5800 and 818ftlbs@4800. I drive everywhere and IF I drive it real nice it can crack 10mpg. Dave
[Re: Dragula]
#1554816
12/29/13 11:42 AM
12/29/13 11:42 AM
Posts: 298 Shelton, Ct.
572_HEMI_Cuda
Shelton, Ct.
I will sell you one of my 700hp pump gas engines, so I can pick this one up:
http://www.racingjunk.com/Street/1820468...wSuperSize=true
I would buy this for sure. I bought my used motor from Tank Crosswhite. He has Tim build his motors with all the best parts. Why wait for parts and fight a new build when this is a proven motor. Call Tim at FHO and ask him about this motor. He will answer all your questions. When i bought mine from Tank I called Tim and felt very comfortable buying it. Tim even gave me a build sheet for the motor. You cant build a motor this cheap.
[Re: 572_HEMI_Cuda]
#1554817
12/29/13 01:11 PM
12/29/13 01:11 PM
FASTFISH420
Central,Ohio
I talked to Tank ayear or so ago about a 572 he had for sale..and yes I seen that engine for sale on RJ.Would like to have a similar deal that 572 Charger runs but with a aluminum block.I want to run in the low nines without a problem,which I think should be a piece of cake.
I had a 572 wedge in the car back in 2001 and it would go 9.30's with a -1 head.
also looking at a F2 procharger deal also for hemi or even a wedge.
www.URE-RACING.com
[Re: FASTFISH420]
#1554818
12/29/13 01:44 PM
12/29/13 01:44 PM
Posts: 3,024 NY
B1duster
NY
[Re: FASTFISH420]
#1554819
12/29/13 01:58 PM
12/29/13 01:58 PM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
Hemi heads outflow the -1 heads easily....Car will be faster at the same weight just based on that alone. An F2 even on an engine as small as my 484 will be 1400hp...kiss low 9's goodby, and say hello to 8's...The problem is packaging one of those into an engine bay...And the cost...$$$
[Re: FASTFISH420]
#1554822
12/29/13 04:02 PM
12/29/13 04:02 PM
Dragula
You going to have Uratchko do the Hemi, Chris?
yes sir!
He does awesome work....$$$$$
Have you thought about a Predator head combo? Makes +70hp over the best Hemi heads out there...
