Just broke-in engine, now what? #155407
11/23/08 06:31 PM
11/23/08 06:31 PM
Townsville
3
3_wheelie Offline OP
Townsville
We just got my 360 started and broke in last night(went great other than the lower rad hose blowin off) and im confused as to what to do with my oil now. I used the Comp break in lube and it recommended to not change the oil for 1000 miles, but since winter hit i wont be driving the car any time soon.
So what should i do? Just drain it now and put the break in lube in with the oil when i get it on the road? also, is it gonna hurt it to sit for a few months without staring it?
YutKillYut Grozny lives!
Re: Just broke-in engine, now what? [Re: 3_wheelie] #155408
11/23/08 07:06 PM
11/23/08 07:06 PM
Definitely change the oil mixture that it was broken in with last night & you can add some breakin lube with the fresh oil change now & no problem if it sits for several months.
