Page 7 of 11 1 2 5 6 7 8 9 10 11
Re: My Gen III Hemi A-body build. [Re: RylisPro] #1552387
12/13/14 10:26 PM
12/13/14 10:26 PM
Nebraska
72Swinger Offline OP
Nebraska
Does anyone know what size are the two oil ports above the oil filter are?
The top one goes to the bearings while the bottom is from the oil pump correct?
I'm trying to figure out what to get for fittings
3/8 NPT
Mopar to the bone!!!
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552388
12/14/14 12:57 AM
12/14/14 12:57 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Ok cool! Going to use -8AN fittings for the 3/8 npt
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552389
12/15/14 07:15 AM
12/15/14 07:15 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Factory recommends 0-40.. But I rckon thats a little thin for hot Climates.
I run 10w-40 Brad Penn...and even that seems like water compared to Cstrol 20w-50
Re: My Gen III Hemi A-body build. [Re: Moparmal] #1552390
12/25/14 01:36 AM
12/25/14 01:36 AM
Nebraska
Nebraska
Cage is getting there. I told my wife and oldest son that if I ever say "I think i'll build myself a rollcage..." again, hit me as hard they can in the face with a frying pan. My son said " dad there isn't any frying pans in the garage...."
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552391
01/03/15 05:45 AM
01/03/15 05:45 AM
Nebraska
Nebraska
Cage is all bent up. Getting the floor plates made and doing the dash bar currently which is stalled out until I get the pedal box notched out. Yes you can have a dash bar with factory wipers,column and dash cluster if your willing to do some customizing.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552392
01/14/15 01:07 AM
01/14/15 01:07 AM
Nebraska
Nebraska
Chipping away....
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552393
01/24/15 01:15 AM
01/24/15 01:15 AM
Nebraska
Nebraska
All welded up. Still have to add the X and rocker bars. Gonna do some tunnel work and will get that done so I don't have work around them. Also going make a new plate for the brack and clutch m/c's on the firewall, then paint cage when its complete. Will get all wiring 75% done before I smooth and paint engine compartment. BTW found a cool cage paint.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552394
01/24/15 09:55 AM
01/24/15 09:55 AM
moparx Offline
moparx  Offline
what "cage paint" is it ?
Re: My Gen III Hemi A-body build. [Re: moparx] #1552395
01/24/15 01:50 PM
01/24/15 01:50 PM
Nebraska
Nebraska
Hammerite dark blue brushable. Gonna roll on first coat and see how it looks then either roll or brush on second coat.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552396
01/25/15 09:46 AM
01/25/15 09:46 AM
moparx Offline
moparx  Offline
is hammerite the brand name ? who makes/markets it ? colors available ?
Re: My Gen III Hemi A-body build. [Re: moparx] #1552397
01/25/15 05:04 PM
01/25/15 05:04 PM
Nebraska
Nebraska
Hammerite is the brand name but its made by Kilz. Rustoleum has some hammered silver's and grays that are cool but this was the only blue I could find.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552398
02/01/15 12:09 AM
02/01/15 12:09 AM
Nebraska
Nebraska
Small gain today, fitting dash and getting ECU,relays,junctions etc. situated before cage and firewall get painted. Have some cool ideas, just not 100% on execution yet lol! Gotta fit dash pad so it can go to upholstery man.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552399
02/08/15 08:13 PM
02/08/15 08:13 PM
Nebraska
Nebraska
Had to relieve some paranoia with 4.05 stroke vs. stock damper. Found a new blem luckily so the sting wasn't SO bad.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552400
02/08/15 08:29 PM
02/08/15 08:29 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I tied my cage in with bailing twine before welding it ...I feel your pain!
A new iron curtain drawn across the 49th parallel
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552401
02/08/15 08:42 PM
02/08/15 08:42 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Very cool! Is that part number 918432?
With what happened with my stock damper separating, I will never use an OEM damper ever again.
It's pricey new at around $400 but worth every penny
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: My Gen III Hemi A-body build. [Re: RylisPro] #1552402
02/08/15 10:37 PM
02/08/15 10:37 PM
Nebraska
Nebraska
Yes it is, 5% OD. Some guys were talking about dampers and strokers and it was the consensus that past 6500rpm and any stroke crank or any combination of the 2, they are pretty much mandatory. People have ran stock 6.1 dampers many times in those situations and the results are not good. Phantom oil leaks and valvetrain problems are the minor problems that occur. So I bit the bullet. One more tidbit before installing one of these, take a 1" flap wheel on a drill, I used a 120 grit, and lightly hone the inside of the hub to take the black oxide off and it will go on nice and smooth with no binding up. My crank has a keyway which these dampers also utilize as another bonus.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552403
02/09/15 04:17 AM
02/09/15 04:17 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Chipping away....
Very cool. Great job!
I like that you got the front turn down bars low to get as close as possible to the shock mounts.
And like that the cage is close to the A-frame and window sills so it looks more stealth and you not so close to hit you head on it just driving on the street.
Re: My Gen III Hemi A-body build. [Re: autoxcuda] #1552404
02/09/15 05:23 AM
02/09/15 05:23 AM
Nebraska
Nebraska
Thanks for noticing Steve, getting that done was what took the time for me. I got a lot of inspiration from Kevin's Dart Lite. The main hoop diagonal/harness bar will be removable so the kids cannot hit their face on it on the street. Looking at the car from the side you can only see the main hoop, and with the windows up it pretty much disappears, I could've lined it up perfect with the quarter window trim but it laid it back more than I wanted.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552405
02/09/15 11:46 AM
02/09/15 11:46 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Looking good Emil! Keep up the good work.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: My Gen III Hemi A-body build. [Re: Uhcoog1] #1552406
02/09/15 01:46 PM
02/09/15 01:46 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I swear to god, I thought some of these pictures were of my car at first glance. its looking great
mine below
