Re: My Gen III Hemi A-body build.
[Re: 72Swinger]
#1552391
01/03/15 05:45 AM
01/03/15 05:45 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Mopar to the bone!!!
[Re: moparx]
#1552395
01/24/15 01:50 PM
01/24/15 01:50 PM
72Swinger
Nebraska
Hammerite dark blue brushable. Gonna roll on first coat and see how it looks then either roll or brush on second coat.
[Re: moparx]
#1552397
01/25/15 05:04 PM
01/25/15 05:04 PM
72Swinger
Nebraska
Hammerite is the brand name but its made by Kilz. Rustoleum has some hammered silver's and grays that are cool but this was the only blue I could find.
[Re: 72Swinger]
#1552400
02/08/15 08:29 PM
02/08/15 08:29 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I tied my cage in with bailing twine before welding it ...I feel your pain!
A new iron curtain drawn across the 49th parallel
[Re: 72Swinger]
#1552401
02/08/15 08:42 PM
02/08/15 08:42 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Had to relieve some paranoia with 4.05 stroke vs. stock damper. Found a new blem luckily so the sting wasn't SO bad.
Very cool! Is that part number 918432? With what happened with my stock damper separating, I will never use an OEM damper ever again. It's pricey new at around $400 but worth every penny
[Re: RylisPro]
#1552402
02/08/15 10:37 PM
02/08/15 10:37 PM
72Swinger
Nebraska
Yes it is, 5% OD. Some guys were talking about dampers and strokers and it was the consensus that past 6500rpm and any stroke crank or any combination of the 2, they are pretty much mandatory. People have ran stock 6.1 dampers many times in those situations and the results are not good. Phantom oil leaks and valvetrain problems are the minor problems that occur. So I bit the bullet. One more tidbit before installing one of these, take a 1" flap wheel on a drill, I used a 120 grit, and lightly hone the inside of the hub to take the black oxide off and it will go on nice and smooth with no binding up. My crank has a keyway which these dampers also utilize as another bonus.
[Re: 72Swinger]
#1552403
02/09/15 04:17 AM
02/09/15 04:17 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Chipping away....
Very cool. Great job!
I like that you got the front turn down bars low to get as close as possible to the shock mounts.
And like that the cage is close to the A-frame and window sills so it looks more stealth and you not so close to hit you head on it just driving on the street.
[Re: autoxcuda]
#1552404
02/09/15 05:23 AM
02/09/15 05:23 AM
72Swinger
Nebraska
Thanks for noticing Steve, getting that done was what took the time for me. I got a lot of inspiration from Kevin's Dart Lite. The main hoop diagonal/harness bar will be removable so the kids cannot hit their face on it on the street. Looking at the car from the side you can only see the main hoop, and with the windows up it pretty much disappears, I could've lined it up perfect with the quarter window trim but it laid it back more than I wanted.
[Re: 72Swinger]
#1552405
02/09/15 11:46 AM
02/09/15 11:46 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Looking good Emil! Keep up the good work.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1552406
02/09/15 01:46 PM
02/09/15 01:46 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I swear to god, I thought some of these pictures were of my car at first glance. its looking great mine below
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
