Re: Hemi Transplant in my '69 Daytona
[Re: Slant6pak]
#1552088
06/03/14 01:29 PM
06/03/14 01:29 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1552090
06/09/14 10:07 AM
06/09/14 10:07 AM
hemi68charger
Houston, Tx
Well, yesteday I tackled the front control arms. Installed the new PST upper bushing and cleaned things up. Love that bushing removal/installation tool. Cosmoline application of the lowers and they are ready for reinstall. The lower control arms have the PST polygraphite bushings as well. I will wait till the motor is in so there is less things in the way. I want to make the installation of the drivetrain as simple and unobstructed as possible. Looks good if I say so out of the garage with a rattle can from RestoRick.
[Re: hemi68charger]
#1552091
06/09/14 10:08 AM
06/09/14 10:08 AM
hemi68charger
Houston, Tx
Cosmoline application ( from RestoRick )
[Re: hemi68charger]
#1552092
06/09/14 10:08 AM
06/09/14 10:08 AM
hemi68charger
Houston, Tx
All done.. Cosmoline is actually darker than what appears in the picture.
[Re: hemi68charger]
#1552093
06/12/14 12:58 AM
06/12/14 12:58 AM
hemi68charger
Houston, Tx
More control arm stuff......... factory markings.......... Orange = passenger side Blue = driver's side.. Disclaimer: I am in no way stipulating that the colors shown are assembly line correct hues of the colors they are...... Now, research on the markings on the valve cover...... Jimbo?
[Re: hemi68charger]
#1552094
06/13/14 09:33 AM
06/13/14 09:33 AM
hemi68charger
Houston, Tx
Thanks to Jim's intel; This is what I'm going with "22"; my final answer, for better or worse, till death do us part...... It is what it is...... I'm going back to the clutch 216 fan style initially. Yes, the fan's dusty and it's not a 070 clutch. ........ I'm losing it..... I need to get the radio noise suppressor as well.......
[Re: ScottSmith_Harms]
#1552096
06/13/14 04:26 PM
06/13/14 04:26 PM
hemi68charger
Houston, Tx
...And a green stamped coil
wellllllllllll, unless I can get one stenciled, this isn't the one that's actually going to be on it. Since I am going with a MSD-6A system, I have to have the MSD Blaster coil, which I bought in black.. Now, if it isn't overly expensive to do that, I'll add that little touch too !!!
Thanks for the feedback Scott......... Always looking to improve the overall OEM look within reason and to the extent of the components I'm using....
[Re: RJS]
#1552098
06/13/14 07:48 PM
06/13/14 07:48 PM
hemi68charger
Houston, Tx
Troy just get the green stamp from ECS to put on the coil of your choice. Ron
Ahh.. OK, I forget the extent of what Dave has to offer.....
Thanks for the tidbit of info...
#1552100
06/14/14 12:08 AM
06/14/14 12:08 AM
hemi68charger
Houston, Tx
Yes, that or just paint it all black, those white stamped coils just scream "I shop at Year One"
Ah man !!! Now, that's cold !!! ( albeit, I have gotten a couple of things from them, like my harnesses from M&H ).....
Well, time for more "stuff". Test fitting the auxiliary transmission fluid cooler lines. These are standard equipment on Hemi-auto cars because of the higher stall speed converter used. I found the perfect place to route the one line, through the strength bend that runs along the latch tray. Not sure why Creative didn't put the line there, it fits with a slight bend forward. Guess it was easier hack the latch tray and route the line instead of forming the tube. I may form the tube some more so it approaches the latch tray at a perpendicular direction.
[Re: hemi68charger]
#1552102
06/17/14 11:08 AM
06/17/14 11:08 AM
hemi68charger
Houston, Tx
New brake system means new fluid. I went with this very high temp racing fluid. Under the hood of this Daytona, it can get warm....good stuff...
[Re: hemi68charger]
#1552103
06/20/14 06:54 PM
06/20/14 06:54 PM
hemi68charger
Houston, Tx
Well, today was the day I brought together the 426 Hemi and Daytona. With the help from Tuffy and Jacob, things went pretty smooth. So, finished is a major milestone in Operation Hemi-Transplant.
Lot more to do, but this is one less thing......
