Page 1 of 6 1 2 3 4 5 6
Hemi Transplant in my '69 Daytona #1552048
12/23/13 08:00 PM
12/23/13 08:00 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Guess this is the more appropriate section for my Hemi transplant in the ole' '69 Daytona of mine....... Here's the link from the "General" section.
HEMI and WINGS thread
Just got an early Christmas delivery from Santa-MegaParts.... Thanks Jaime.......
A bounch of parts per example:
both battery cables, carb air cleaner studs, various fasteners, date-coded Hemi spark plugs cables, etc...... Will be nice to see these on a freshly painted motor.....
Troy
Houston Mopar Connection Club
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552049
01/03/14 09:15 PM
01/03/14 09:15 PM
Houston, Tx
Houston, Tx
Right before my family's Christmas vacation, I received a bunch of parts from Jaime at MegaParts USA.
Today I replaced the intake fasteners that were on the motor with an OEM correct set with the proper return spring and throttle brackets. I also mocked up the throttle/kickdown assembly to make sure everything works fine. The kickdown is made by Brian Brady at crossramconnection, so quality stuff. I knew I forgot something, the rear body ground strap. So, that'll be on my next list. Need to have that installed prior to detail painting. I am going to go ahead and order a complete Hemi k-member and proper brackets for the car.... Heard some negative things about the Schumacher adapters and can't ever get ahold of John Azzurra to inquire about his hemi motor mount adapters.....
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552050
01/03/14 09:16 PM
01/03/14 09:16 PM
Houston, Tx
Houston, Tx
rear
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552051
01/04/14 01:04 AM
01/04/14 01:04 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
this is the awesomesauce troy.
Re: Hemi Transplant in my '69 Daytona [Re: Golden-Arm] #1552052
02/06/14 12:04 AM
02/06/14 12:04 AM
Houston, Tx
Houston, Tx
Some more goodies recently arrived.....
My new cermanic coated TTI headers, .96 torsion bars AND the hemi k-member and motor mount brackets.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552053
02/06/14 12:04 AM
02/06/14 12:04 AM
Houston, Tx
Houston, Tx
k-member
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552054
02/06/14 12:05 AM
02/06/14 12:05 AM
Houston, Tx
Houston, Tx
candid shot....
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552055
02/08/14 02:17 PM
02/08/14 02:17 PM
Houston, Tx
Houston, Tx
Another piece to the puzzle, got my dolly back...
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552056
02/11/14 12:52 AM
02/11/14 12:52 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
and they say boys shouldn't play with dollies.....
Re: Hemi Transplant in my '69 Daytona [Re: Golden-Arm] #1552057
03/16/14 01:35 AM
03/16/14 01:35 AM
Houston, Tx
Houston, Tx
Did some detailing today ( prefect day since it rained most of it )...
1. freshened up the valve covers with a new coat of paint
2. installed the fuel line and pump ( need to get fittings )
3. painted the thermostat housing I got ( proper one with the right casting number )
4. installed the driver's side motor mount insulator and painted it ( as it was on the motor when painted; of course, after I bought another one, I found the original I had all along sitting in the cabinet...... ). Oh well, now I have an extra......
5. installed the alternator with, what I believe it, the proper pulley ( not the late model dual pulley you get on stuff now )..... Along with that, the brackets as well.
Looks good regardless...
May not be 100% perfectly OEM correct, but it's not half bad either.....
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552058
03/16/14 01:36 AM
03/16/14 01:36 AM
Houston, Tx
Houston, Tx
another
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552059
03/16/14 01:40 AM
03/16/14 01:40 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That looks GREAT Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552060
03/16/14 12:10 PM
03/16/14 12:10 PM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
Re: Hemi Transplant in my '69 Daytona [Re: v8punch] #1552061
03/18/14 12:30 AM
03/18/14 12:30 AM
Houston, Tx
Houston, Tx
One step closer... My AR140 AR Engineering .375 crank spacers arrived today... From the looks of it, it looks dead-on.. I think this was a relatively good solution and quickly at about $80 total........ I just need to get some longer bolts...... Hopefully I can find the same type of bolts that are OEM, but a little longer.......
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552062
03/18/14 12:30 AM
03/18/14 12:30 AM
Houston, Tx
Houston, Tx
Another...
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552063
03/21/14 04:43 PM
03/21/14 04:43 PM
Houston, Tx
Houston, Tx
Some more today.......
Power steering pump... I got my refurbished Federal Power Steering pump back today with the proper Hemi pulley installed. I painted it all up and installed. I am pleased thus far with the alignment of water pump, alternator, crank and p.s. pump with the AR140 spacers for the crank.... Also got my tranny dipstick for a hemi and fuel fittings for the fuel pump. I am looking into getting the proper squeeze fuel line clamps. A little OEM-overkill, but that's what I'm all about as long as it doesn't break the bank or take food off the table...... ( or beer in the Frig. )
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552064
03/21/14 04:44 PM
03/21/14 04:44 PM
Houston, Tx
Houston, Tx
fuel pump area...
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552065
03/21/14 04:45 PM
03/21/14 04:45 PM
Houston, Tx
Houston, Tx
Also, pleasant surprise. I was taking off the remanufacture decals placed on the alternator I got last week. Low and behold, the darn thing is a proper 1969 383/440 alternator !!! with a date code of 4-69 no less !!! The same month my Daytona was built !!! This alternator is a keeper !! With the proper era pulley, she looks the part......
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552066
04/02/14 09:41 PM
04/02/14 09:41 PM
Houston, Tx
Houston, Tx
Ok, today lifted the motor off the cradle and put on an engine stand so I could tinker with the headers and modify the dipstick tube to accommodate the headers..... I think it came out pretty cool...
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552067
04/02/14 09:42 PM
04/02/14 09:42 PM
Houston, Tx
Houston, Tx
Another of the headers
Troy
