Anyone have a Gearvendors OD in their car??
#1552008
12/23/13 05:59 PM
12/23/13 05:59 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
My vert is used for just cruising around on a nice day. Has 2.94 rear gears( original 440/727 in it). Have always thought it would be fun to up the rear gears to 3.55 or 3.23, but would like a good hwy cruise RPM without working the motor.. Tell me about your gearvendors O/D?? install, dependability, servicing, any problems?? Thanks
Re: Anyone have a Gearvendors OD in their car??
[Re: floridian]
#1552010
12/23/13 09:35 PM
12/23/13 09:35 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
As already mentioned, those are modifications you will have to perform. I did mine in a weekend plus a Monday for the driveshaft return. Ran the foot switch next to the hi-beam, the toggle into the center console. I have a 440/727 with 3.55s and I can drive 80mph @2200rpm. Had it in there since 2007 and have about 7000 miles on it. She is a weekend car. The only thing I goofed on was the GVO sat up against my H-Pipe for 2000 of those miles and the gasket burned out. They sell em for 6 bucks each and I replaced it already. The downfall you will realize is that you have to to run Mopar Manual Synthetic 75w85 at $15 a quart. I did some digging and found that MT-85 will work just as good from Redline and I bought a few bottles from eBay.
I still can't get the whole synchronization down of shift, OD, shift, OD, to split the gears but the 4th gear overdrive works fine for me
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1552011
12/23/13 10:15 PM
12/23/13 10:15 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
I've had a GV in my challenger since 2005. As said by an earlier poster, pretty simple install. I'm running 3.91's. Cruise down the SoCal freeways at 70-75 at 2500-2600 rpm. Absolutely love it. G-bob's Gearvendors install
[Re: rapom]
#1552026
12/29/13 03:32 AM
12/29/13 03:32 AM
Posts: 610 White Creek, NY
408cuda
White Creek, NY
Have one in this car http://youtu.be/Pc-4z5WrNwc 74 cuda 408 stroker and love it. Easy to install, slight dimpling in floor and minor wiring. Evidence above of abuse. Even shifted into 2nd over at the strip WOT,, no gain on my combo but good testament to the shift quality and durability. Wanted to go 518 but they were pretty hard to find at the time for any kind of fair $ and the GV 727 combo is proven tough. I hear a lot of concerns on driveline angles but I had no problem getting mine good and its one of the smoothest 11 sec cars I imagine you'll see. Well as far as old muscle goes anyhow
[Re: 408cuda]
#1552027
12/30/13 05:44 PM
12/30/13 05:44 PM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
One of my longterm projects is installing the Laycock-deNormanville OD in my Gremlin. (Later Gearvendors units are virtually identical to the LdN unit - I can even get parts for it from GV!)
Lucky for me, the LdN unit was a factory option in '75 and '76, even though my Gremlin is a '70 it's still a bolt-in process!
I'm curious to see how it'll perform as it's a three-speed with the OD, and only a 3.08 gear. The steepest gear one could order with the unit is only 3.08.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
