Scott Smith can you post 360* of this engine?
#1551806
12/23/13 01:48 AM
12/23/13 01:48 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Ibelieve you are the origin of this engine, really post as many as is reasonably possible. It is a good model for me (and others), I think I remember it being a 71 but I believe it is accurate for my AAR (of course the intake and carbs are slightly different ![](/ubbthreads/images/graemlins/grin.gif) ). OR if you have a better one I gladly except that too. Thanks in advance, Kevin
Careful, your character's showing!
Re: Scott Smith can you post 360* of this engine?
[Re: ScottSmith_Harms]
#1551810
12/23/13 02:06 PM
12/23/13 02:06 PM
mopar346
I'm with John, all of them.
At that moment I was thinking of the clutch pivot bracket and bolt. As I get closer there a lot of little things that come up, the heater hose bracket bolt for instance. If I had a good reference engine with 8 or 10 good shots in a pregression around it I wouldn't have to ask a lot of questions.
And I see some errors as well, PCV grommets, starter area has no overspray, shifter rods too dark, shifter too bright and that is just a keep view but it is what I believe to be correct in most aspects on the build.
Thanks, Kevin
[Re: cdp]
#1551812
12/24/13 05:21 AM
12/24/13 05:21 AM
Posts: 27,485 So Cal
autoxcuda
So Cal
where can you get a 6v carb cover like that at? I need one. Thanks
Troy made it. PM him ( Troy ).
