5.9 magnum swap alternator question
#1551710
12/22/13 08:44 PM
12/22/13 08:44 PM
Posts: 51 Jacksonville, AR
dmckeehan
Jacksonville, AR
Swapping in a 97 5.9 magnum into my 1981 Crew cab. Converting to a Carb, but have heard that i may need to use the existing external regulator with the new style alternator. Is this correct? Thanks for the help!
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205 2002 3500 extended cab, 4x4, Cummins and 6 speed 1997 Ram 2500 5.9 with 35 Boggers - Mud Racer 1993 Dakota 4x4, Dana 60's front and rear - work in progress 1992 Dakota 2wd short bed, awaiting 440 swap
