daytona vs superbird wings. Different? #1551391
12/22/13 04:23 AM
12/22/13 04:23 AM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Just looking at pics of a local car show. The 69 Daytona's wing looks alot more vertical than the bird's, and it also appears to be closer to the rear by about 6" or so. This the way it was from the factory?
Just curious.
Codfish
Re: daytona vs superbird wings. Different? [Re: codfish] #1551392
12/22/13 05:02 AM
12/22/13 05:02 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
YES, IIRC the headlight door/buckets are the only "special" parts used by both cars.
Re: daytona vs superbird wings. Different? [Re: 6bblgt] #1551393
12/22/13 05:37 AM
12/22/13 05:37 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Re: daytona vs superbird wings. Different? [Re: 6bblgt] #1551394
12/22/13 10:32 AM
12/22/13 10:32 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Yeap,,, Wind deflectors will position themselves over the same location, but the Superbird has the two holes to attach points whereas the 500/Daytona doesn't......
Troy
Houston Mopar Connection Club
Re: daytona vs superbird wings. Different? [Re: 6bblgt] #1551395
12/22/13 01:38 PM
12/22/13 01:38 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The wingcar program being on as much a shoestring budget as possible had the assembly of the vehicles using as much as possible from the initial tooling from 69 into 70 vehicles, the headlite doors/buckets as mentioned where basically the same, the front spoilers are the same, Superbird Z bars are just stripped down Daytona Z bars (nose supports), the Superbird latchtray is just the Daytona latchtray turned 180 degrees, the end tabs cut off, a new latch hole punched, and the old latch hole plated over/spot welded, and a few new mounting holes added, basically just reworked for a new application, the rear wing uprights are different, but the center section being an extrusion piece was merely a cut to length/drill/tap operation for the vendor, Tona centers are 57 1/2" in width, Super birds are 55 1/2" widths, wings braces are the same, just different lower trunk floor attachment brackets, and the addition of a flat washer added/welded to the tops of the Birds braces, the A pillar Stainless moldings on the Bird, are just Daytona, but modified with 2 screw holes to facilitate an easier mounting system,everything else is vehicle/year specific
Mike
Re: daytona vs superbird wings. Different? [Re: DAYCLONA] #1551396
12/23/13 05:21 AM
12/23/13 05:21 AM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Thanks for the enlightenment guys.
Cool pic too.
Codfish
Re: daytona vs superbird wings. Different? [Re: DAYCLONA] #1551397
12/23/13 01:42 PM
12/23/13 01:42 PM
Houston, Tx
Houston, Tx
Mike
Troy
