Re: Notched frame rail questions
[Re: sshemi]
#1551049
12/21/13 11:17 AM
12/21/13 11:17 AM
Posts: 10,155 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There may be other solutions,,,,,,,,,, what are your goals? Better 60 ft? More consistent? Sometimes the tire is plenty big, it just needs some suspension upgrades. A full run down of your combo would help a lot. Motor, driveline, tires, suspension, best 60 ft, best et, average variance in 60 ft over a day.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#1551050
12/21/13 11:29 AM
12/21/13 11:29 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
The car is a work in progress right now ! It's got full cage 7.50 cert. Ladder bars, coil overs tubs are after market alum Dana 2" shorter than stock each side 3.73 gears ! Motor is in the build process right now but it's 4.50 bore 4.50 stroke alum block gen 2 hemi with F-2 procharger, th400 trans, glass front end, glass deck lid, stock doors but lightened as much as I could with out bending when leaned on ! Got factory back seat stock passenger seat, kirkey drivers ! Aftermarket race car steering column ! It's going to be 10.5 tire car but want the ability to go bigger tire if I should want to ! I'm hoping to have the car done for Norwalk if all goes right !
[Re: 70dusterjohn]
#1551052
12/21/13 03:11 PM
12/21/13 03:11 PM
Posts: 43,911 Bend,OR USA
Cab_Burge
there are three choices with the Mopar type front spring box location kit, centered in the rear sub frame like the Mopar chassis book shows, the other two are leaving one side or the other of the sub frame and mounting one side of the box agianst that I've done it all three ways in different cars My current 1969 dart has the box mounted against the inner sub frame rail so the leaf springs will clear the stock gas tank, I did have to massage the passenger side of the gas tank to clear the leaf springs If your running a fuel cell mount the box against the outer sub frame rail and use(weld) a full length strap from the inner edge angled to the sub frame on a 45 degree angle I used the stock rear spring hangars and had them welded into the rear sub frame by Ving the rear sub frame and pointing the hangers straight up . I did have them moved forward so the stock hangers where pointed at a 30 degree angle from the rear spring eye to the moved hanger IHTHs, I would take some pictures but the car is put up for now and not easy to take the picture of the front box
[Re: 70dusterjohn]
#1551057
12/21/13 09:12 PM
12/21/13 09:12 PM
Posts: 916 SE Washington
Forest
SE Washington
Yep that's what I'm looking for. Already running ladder bars with aftermarket tubs ! You got anymore photos of that ? Thanks John
I can't find any, I think I used 16g plate to notch the rails and made sure to weld the 6 x 6 plates to it along 1 edge. Your upper coil over tube also helps support the frame rail...
[Re: 70dusterjohn]
#1551059
12/22/13 10:02 AM
12/22/13 10:02 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
How much of a bigger tire would you like to go in the future? I had 29x13.5 Hoosier QTP under my Dartsport with rails in stock location and unmodified. I think the Dana housing was cut to was 52.5 and I had 15x10x6.5BS weld wheels on it.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1551062
12/22/13 06:39 PM
12/22/13 06:39 PM
gregsdart
572 with a blower? No question in my mind, you need all the tire you can stuff under it, and THAT won't be enough. Do it right, and do what it takes to put the absolute biggest tire you are willing to run under it. Traction will be poor no matter what, except MAYBE on a prepped track.
