Re: 94 Caravan drivetrain prob.
[Re: MNobody]
#1550730
12/20/13 10:41 PM
12/20/13 10:41 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
May be a worn pump if it is a 604 trans. It would cause the CVI to run high and that would cause it to bang in gear and on some downshifts. The addaptive memory would learn of the higher count if the pump took time to build pressure when first started and put in gear. But thats only if its the electronic 604 (41TE) trans. Ron
