Anyone know of anti-corrosion sprays or dip-type coatings for aluminum carburetor parts that can be applied by a do-it-yourself-er?
Especially with the prevalance of ethanol-blended pump fuel today, I'm concerned that the aluminum parts in many aftermarket carbs which used to be made of a zinc alloy (e.g., main bodies, metering blocks, float bowls) are more likely to suffer the corrosive effects of modern fuel.
I don't care if the spray or coating changes the part's color, if it serves an anti-corrosion purpose. Any ideas or suggestions?
Thanks,
Brad
