A-Body Alterkation Front Wheel and Tire Question #1550558
12/20/13 02:56 PM
12/20/13 02:56 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
Running a 20x12 on the rear with a 315/35/20 on my 68 Barracuda
I want to run the largest front wheel and tire combo on the front that I can.... and keep the car low
I was thinking that a 19x8 but I dont know about tire size and backspace.
We will mock it up but if I can get an idea to get me started I will be good
Thanks for the help guys
Josh
Re: A-Body Alterkation Front Wheel and Tire Question [Re: joshking440] #1550559
12/21/13 01:01 AM
12/21/13 01:01 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I don't know how the alterk compares to stock, but I run 18x9 with a 6.4bs.
Re: A-Body Alterkation Front Wheel and Tire Question [Re: BergmanAutoCraft] #1550560
12/21/13 02:26 PM
12/21/13 02:26 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I can fit a 275/40/17 (25.7" dia.) on a 17x9 rim easily with the right backspace on my 68 Barracuda. But the bottom front fender lip needs to be clipped/bent in a little.
As the overall tire diameter increases room for the tire width will decrease.
Re: A-Body Alterkation Front Wheel and Tire Question [Re: joshking440] #1550561
12/22/13 12:16 AM
12/22/13 12:16 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Josh
315/35/20 is really tall! In a wide front I have never seen anyone go bigger/taller than the 275/40-17 or 275/35-18 without running a fender flare. I remember seeing a Canadian autocross car with a 315/35-17 on all four corners with fender flares.
You need to talk with Bill. I had a discussion with him once, I seem to remember that the track width was the same as my '75 K frame with Cordoba rotors. I also think that the Alter-K can not run as wide a wheel because of the steering arm on the spindle. Speak to Bill, he should know.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: A-Body Alterkation Front Wheel and Tire Question [Re: 68cuda440] #1550562
12/22/13 02:03 AM
12/22/13 02:03 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Cam and Pat Rittich in British Columbia
Re: A-Body Alterkation Front Wheel and Tire Question [Re: 68cuda440] #1550563
12/23/13 11:59 AM
12/23/13 11:59 AM
Indy
Lunch is on me!
Lunch is on me!
Indy
Im ok with a 275 Width 26" tall on a 19" wheel.
Or maybe a little narrower
Re: A-Body Alterkation Front Wheel and Tire Question [Re: joshking440] #1550564
12/23/13 12:45 PM
12/23/13 12:45 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I know on my B-body AlterKation, the spindles are about 1" further out than with the stock K-frame. So you may need a little more back spacing on the wheel to get it to tuck in well enough to have clearance. (sorry - no a-body experience)
Re: A-Body Alterkation Front Wheel and Tire Question [Re: joshking440] #1550565
12/23/13 02:52 PM
12/23/13 02:52 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
275 wide and 26" tall will fit. Just need to float those outer dimension in and out with the correct backspacing.
Re: A-Body Alterkation Front Wheel and Tire Question [Re: autoxcuda] #1550566
12/23/13 03:18 PM
12/23/13 03:18 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Look for a 05+ 18x9 Mustang wheel for mock up. It would be the cheapest closest option.
Mopar to the bone!!!
