Re: 440 into a duster
[Re: mcmopars]
#1550530
12/20/13 01:27 PM
12/20/13 01:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The easiest way is to use a motor plate in front... might need a trim on the K-member to clear the pan... I would get a set of headers in the beginning so you can center the engine to clear things
[Re: mcmopars]
#1550532
12/20/13 02:04 PM
12/20/13 02:04 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I pretty much agree with everything stated above. All good advice. I would suggest you join 'bigblockdart.com' LOTS of good info on their site. As others have said, they are a pain to work on. I did a RB in a '68 Valiant a few years ago. All stock inner fenders, suspension/steering/etc. The TTI headers were used and fit well but a real &##$%@ to change starter. I would go with the ARE motor plate at the front. Gives more room in the header area.
If you like drag racing, support your local track.
[Re: 70dusterjohn]
#1550536
12/20/13 03:24 PM
12/20/13 03:24 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I did a 440 duster years ago. I went with a motorplate and fenderwell headers. It worked, but the sheer size of upper end of the RB block created all kinds of issues. My : A low-deck 451 or 470 would be a LOT easier.....
[Re: Thumperdart]
#1550539
12/20/13 05:29 PM
12/20/13 05:29 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Really comes down to how bad to want it. I put a 440 in my Demon in 1978 with the DC K member, fenderwell headers, all I knew of at the time. Went right in no problem.
I now have CPPA headers, under chassis, bought in 1985 or so, cant remember. Mini starter goes right in, plugs are a little tight, but if you want it, it will work. No issues with valve covers, although I took the heater motor out.
For the person that doesn't know, when you open the hood and wall to wall engine, it is impressive.
[Re: StealthWedge67]
#1550540
12/20/13 05:43 PM
12/20/13 05:43 PM
Posts: 4,647 aotearoa
rebel
aotearoa
headers & plugs are so much easier & a stroked 400 is an awesome option for power.
[Re: 69B3GT]
#1550544
12/20/13 06:43 PM
12/20/13 06:43 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
would it be a lot better with an altercation front end? i'm going to be putting an RB in my 68 cuda soon.
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: mcmopars]
#1550546
12/20/13 07:44 PM
12/20/13 07:44 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Like already mentioned, we need to know what your intending to do with the car. Even though I'm a big block guy my vote for your car would be a stroker small block with a decent set of heads, cam, and intake.
If you go big block, definitely go with a 400 based low deck, and Proparts semi-fenderwell headers are an option.
I said I'd never again build a big block a-body with underchassis headers but of course I'm doing it again right now, just because I ran across some great deals on big block stuff.
I went with an AR-Engineering motor plate and I bought some 1 3/4" B-body headers(for now) that were already in a big block low deck a-body.
