how are big block lifters different? #1550010
12/18/13 11:38 PM
12/18/13 11:38 PM
ST clair shores MI
moretoys Offline OP
moretoys  Offline OP
ST clair shores MI
why do I see lifters with a part number for 1958-1967. then another number for 68 and up? What is different about them?
What happens if I put later parts into a 1966 block?
Re: how are big block lifters different? [Re: moretoys] #1550011
12/18/13 11:52 PM
12/18/13 11:52 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The original 67 and older used a smaller pushrod cup.
Keith
Re: how are big block lifters different? [Re: Dunnuck Racing] #1550012
12/18/13 11:55 PM
12/18/13 11:55 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Its fine to run the later lifters, as far as I know the early style lifters are not available. You will need later style pushrods that aren't tapered, but no issues otherwise.
Re: how are big block lifters different? [Re: GTX MATT] #1550013
12/19/13 12:28 AM
12/19/13 12:28 AM
ST clair shores MI
moretoys Offline OP
moretoys  Offline OP
ST clair shores MI
Thanks. makes sense.
I was going for a long shot,I have a strange oil pressure problem,wasn't sure if something like oiling hole was higher/ lower. I was hoping anyway. I'll need to check for markings, maybe this block uses oversized lifters?
Re: how are big block lifters different? [Re: moretoys] #1550014
12/19/13 02:24 AM
12/19/13 02:24 AM
Provide detail on what's going on, maybe we can help
