15x7 steel wheels?
#1549663
12/18/13 01:37 AM
12/18/13 01:37 AM
Posts: 364 Houston, Texas
Slant6pak
Houston, Texas
Hey guys,
I'm planning on hitting the junkyard in the next few weeks and plan to look for a set of plain 15x7 wheels for my new project.
When did 15x7 wheels become available vs. 15x6 or 15x6.5? Is there any way to tell the width of wheel with a tire mounted?
Also, did the for lack of better term, "tabs" for the dog dish center caps ever change? I'm planning on running a set of 1968 Dodge hubcaps.
2016 Challenger Scat Pack Shaker 1000 ci Brass Era Speedster project
Re: 15x7 steel wheels?
[Re: Slant6pak]
#1549664
12/18/13 03:15 AM
12/18/13 03:15 AM
Posts: 17,551 Las Vegas, NV
6bblgt
Las Vegas, NV
15x7.0 wheels became available for the '70 model year (& are expensive thru model year '73). The most commonly available junkyard 15x7.0" wheels are from the late '70s - early '80s from Fury, Diplomat, 5th AVE, etc. the extra holes are for bolt on wire wheel cover attaching parts. The '68 & newer MOPAR hub caps are 9" in diameter (earlier & FoMoCo used 10"). a set on-line
[Re: Slant6pak]
#1549665
12/18/13 10:38 AM
12/18/13 10:38 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
If you're going to hit the yards here in Houston, good luck... Pick-a-Part is about the only thing out there any more with half a chance on finding anything. I did however find a complete set of proper looking 15x7 steelies. They came off a '79 Cordoba. The one in Dan's link are the later versions that are different than the early years ( if you don't care that is ). They have a bump in the center part where it touches the rim as opposed to being smooth all the way ( see attached picture ). I have a pair of police 15x7's ( maybe 15x8's, I'll have to look if interested ).
Good luck on the search, happy picking.......
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1549666
12/18/13 11:36 AM
12/18/13 11:36 AM
Posts: 4,086 Strathroy, Ontario
BS27R1B
Strathroy, Ontario
The 70-71 15X7 rims have a part number ending in 450. Look for it near the valve stem hole. Later 15 X 7 wheels that are pretty well identical have a part number ending in 071.
The 450 wheels will make your day if you find any as those looking for that specific wheel will,generally pay a premium for them.
'.. it was long ago and it was far away, and it was so much better than it is today..' Jim Steinman
[Re: BS27R1B]
#1549667
12/18/13 11:57 AM
12/18/13 11:57 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Not sure of the width but some 1/2 ton trucks through the 70s run a 5 lug 15 that fits cars, even has an H but it's sideways. Not sure if the center cap fits, I never tried it. Might be worth a look.
Careful, your character's showing!
[Re: Slant6pak]
#1549672
12/18/13 09:06 PM
12/18/13 09:06 PM
Posts: 8,483 Highland, MI.
Sunroofcuda
Highland, MI.
If you can find any non-police Mopar 15x7's at any junkyard nowadays, good luck. The old "450" wheels only came on some of the 1970-71 performance models - they never came on Furys or station wagons. They were unique because they had 14" centers on them. You will never find any of those at a junkyard. But have fun looking. Also, if you find a wheel, it MIGHT be true & balance for you!
[Re: Sunroofcuda]
#1549673
12/18/13 10:14 PM
12/18/13 10:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
M bodies had 15 x 7" wheels, both police and non-police.
