Project 1972 D100 #1548727
12/16/13 11:08 PM
12/16/13 11:08 PM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
Been putting this off for a while. Gonna swap motors from the 318 a 360 I picked up for $80 :P
And while I'm in there, I'll be cleaning up the frame and painting the engine bay body color.
Tear down begins:
Re: Project 1972 D100 [Re: magnum440d100] #1548728
12/16/13 11:13 PM
12/16/13 11:13 PM
woodcrest, CA
woodcrest, CA
Had to stop here for tonight. More tomorrow
Re: Project 1972 D100 [Re: magnum440d100] #1548729
12/18/13 06:34 PM
12/18/13 06:34 PM
woodcrest, CA
woodcrest, CA
Got the rest of the front sheet metal off
Re: Project 1972 D100 [Re: magnum440d100] #1548730
12/18/13 06:51 PM
12/18/13 06:51 PM
woodcrest, CA
woodcrest, CA
Drivers side suspension.
Re: Project 1972 D100 [Re: magnum440d100] #1548731
12/18/13 06:54 PM
12/18/13 06:54 PM
woodcrest, CA
woodcrest, CA
Passenger suspension.
Had to stop for the day. Have the flu. Working between sickness.
Re: Project 1972 D100 [Re: magnum440d100] #1548732
12/18/13 07:50 PM
12/18/13 07:50 PM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
Good to see another of one of the most beautiful pickups ever made get some love.
OIF V and OEF X veteran and proud of it!
Re: Project 1972 D100 [Re: 69HemiGTX] #1548733
12/19/13 05:16 PM
12/19/13 05:16 PM
woodcrest, CA
woodcrest, CA
Thanks.
The truck was bought way back when by my Grampa. My older late brother and I helped my Grampa work on her. So this truck has sentimental value. I'm doing a quick job fixer her up for now. Just to make her more dependable since I do drive her just about everywhere.
Gonna drop the $80 360 in there for now while I save to finish the other 360. Still need rods, and a flywheel for that 360.
No updates today. I feel ok. Not great, just ok, and its raining. So nothing till tomorrow
Re: Project 1972 D100 [Re: magnum440d100] #1548734
12/20/13 09:46 AM
12/20/13 09:46 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Check the frame around the steering box while you have easy access by pulling the bolts. I had 1 truck crack here.
Re: Project 1972 D100 [Re: wally426ci] #1548735
12/20/13 05:40 PM
12/20/13 05:40 PM
woodcrest, CA
woodcrest, CA
Thanks for the tip. I'm not there just yet, but I do remember we had to drill 1 hole when we went to power steering. It wouldn't surprise me if it did crack there. My passenger side motor mount pad is cracked too.
I DO live on a dirt road. It is fairly maintained, but the tractor tires leave bumps in the road. And I do/did work construction where we were required to drive over cow grates to shake off the mud before we went out to the exit. I avoided them as much as possible.
I wonder if any of that contributed to any cracking?
I've been driving it for the past ~10 years, but we've owned it for about 20.
Re: Project 1972 D100 [Re: magnum440d100] #1548736
12/21/13 02:59 AM
12/21/13 02:59 AM
woodcrest, CA
woodcrest, CA
Got the $80 360 cleaned and sprayed. Not using the van valve covers/intake or oil pan. Those are just there for overspray protection. The motor was clean, just it was ford blue lol. Supposed to have been rebuilt. I dunno. It does have a double roller in her so she's been cracked open at least for a timing set change. It's a 77 and it passed California smog, so she's gotta run decently
Re: Project 1972 D100 [Re: magnum440d100] #1548737
12/22/13 12:19 AM
12/22/13 12:19 AM
woodcrest, CA
woodcrest, CA
Tore the 2bbl intake off of the $80 motor. Then pulled the 4bbl and valve covers off of the 318. (Was using a 360 4bbl on a 318 haha) They're not installed, just setting on there, because its outside.
Tomorrow I will clean and paint the intake and valve covers.
Re: Project 1972 D100 [Re: magnum440d100] #1548738
12/22/13 12:24 AM
12/22/13 12:24 AM
woodcrest, CA
woodcrest, CA
Inside of the $80 motor
Re: Project 1972 D100 [Re: magnum440d100] #1548739
12/22/13 12:33 AM
12/22/13 12:33 AM
woodcrest, CA
woodcrest, CA
My poor truck. I feel bad robbing parts off her for the other motor. It's worth it though
Re: Project 1972 D100 [Re: magnum440d100] #1548740
12/22/13 01:03 PM
12/22/13 01:03 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Looks like you're making good progress. If the oil pan that's on it is sealed up and working, why not use it? Is there a difference in a truck pan, and a van pan? The one off your 318 won't fit the 360. Inside of the motor sure looks clean!
Re: Project 1972 D100 [Re: JDMopar] #1548741
12/22/13 02:21 PM
12/22/13 02:21 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Nice project. I always had a soft spot for these trucks..The van oil pan the sump is in the front ,the Truck pan the sump is in the back.. To you have a externally balanced torque converter or are you gonna weld on some weights ?
Re: Project 1972 D100 [Re: JDMopar] #1548742
12/22/13 03:00 PM
12/22/13 03:00 PM
woodcrest, CA
woodcrest, CA
The guy had to take off the oil pan to get it out of the RV/van. It sat in a garage uninstalled and rusted fairly bad inside. I have an extra stock 360 pan that I'll just put on, since I'll be going to an aftermarket pan for the built 360. This 360 is just going in because the 318 is done. It's still good/ok but needs to come out because I wiped a cam lobe and have been finding speckles in the oil. It's gonna come out and apart for an inspection. It's been rebuilt in 1999-2000, but should only have about 70k.
I also have a high volume oil pump I'll put in the 360 just because. I haven't had a good look at the oil pump on the $80 motor. It's been on the cherry picker and I just haven't had the guts to get under it and look haha
Re: Project 1972 D100 [Re: johnscudashop] #1548743
12/22/13 03:19 PM
12/22/13 03:19 PM
woodcrest, CA
woodcrest, CA
None of the above
Truck came as a 3 on the tree a230. But that was swapped for an A833od for gas mileage. I'm hoping the 833 hold up behind the 360. If not, I'll have to see about a 5 speed
For now, I'll order a flywheel from mazzolini because he's down the street from me and he's a great guy.
Re: Project 1972 D100 [Re: magnum440d100] #1548744
12/23/13 12:00 AM
12/23/13 12:00 AM
woodcrest, CA
woodcrest, CA
Got the intake stripped primed and painted. I would have installed it, but paint is still fresh. Don't want it chipped by the bolt holes.
Got the valve covers stripped. Have some detail work to do. Clean the crevices and straighten the holes.
And yes I did reinstall some smog devices (egr valve) and thermostatic vacuum switches. Even though its going in a 72, once the race motor is built, this ones going in something else. I may just find me a 75-78 dodge shorty van
Gettin there
Re: Project 1972 D100 [Re: magnum440d100] #1548745
12/23/13 07:12 PM
12/23/13 07:12 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
looking good! that $80 engine looks pretty clean inside. That one pic reminds me I need a couple plug wire holders.
1981 Dodge D150 360 auto
Re: Project 1972 D100 [Re: basketcase] #1548746
12/24/13 11:40 PM
12/24/13 11:40 PM
woodcrest, CA
woodcrest, CA
Thanks. I think this is a good motor
Got the 318 and trans pulled
