97 dakota 42re pump failure or? #1548470
12/16/13 03:29 PM
12/16/13 03:29 PM
anacortes,wa
78asprin Offline OP
78asprin  Offline OP
anacortes,wa
My little v6 Dakota started acting up this morning. My girlfriend went out and started it, let it warm up, hopped in and as soon as she put it in reverse, it died. She put it in park, started it, put it in reverse and it did it again. I went out and tried it, it stayed running just fine, but its making a funny noise from up front. It wont do it in neutral or park, only in gear. I backed it up and drove it forward a few times and noticed it started leaking tranny fluid from the bellhousing area.... Any ideas on whats going on? Its a rebuilt 42re in a 97 v6 2wd dakota. It only has 23k miles or so on the rebuild.
Re: 97 dakota 42re pump failure or? [Re: 78asprin] #1548471
12/16/13 04:13 PM
12/16/13 04:13 PM
Guitar Jones Offline
Torque converter. Probably took out the bushing in the pump as well.
Re: 97 dakota 42re pump failure or? [Re: Guitar Jones] #1548472
12/16/13 09:41 PM
12/16/13 09:41 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
probably split the converter hub. Id say its pump and converter time.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 97 dakota 42re pump failure or? [Re: 71yelladustr] #1548473
12/17/13 04:56 PM
12/17/13 04:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'96-up has the milled flat pump drive, they don't crack as often as the slot drive but.......
Re: 97 dakota 42re pump failure or? [Re: John_Kunkel] #1548474
12/17/13 11:49 PM
12/17/13 11:49 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
That's correct I have also seen VB problems and cooler blockage cause them to die when put into gear.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 97 dakota 42re pump failure or? [Re: dusturbd340W5] #1548475
12/23/13 12:37 AM
12/23/13 12:37 AM
anacortes,wa
78asprin Offline OP
78asprin  Offline OP
anacortes,wa
So I took it in to the shop and had them look at it. They thought it was the IAC causing it to die. After cleaning the TB and replacing the IAC, replacing the serpentine belt and tensioner, and doing a carbon clean-out,it seems to run ok. No more noise while in gear but it still stalls in reverse sometimes, more when it is warmed up. As far as leaking, it only leaks a few drips every now and again. Mechanic said it may be coming out of the vent in the pump. Does this sound right?
