what grit for flex ball hone #1548089
12/15/13 11:36 PM
12/15/13 11:36 PM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
pulled engine decided to freshen it up. what grit for ball type hone to take shine off cylinder walls? thanks Bradley
Re: what grit for flex ball hone [Re: roadrunnerreds] #1548090
12/15/13 11:47 PM
12/15/13 11:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a 160 but they load up pretty quick even with oil
(I'm pretty sure its a 160)
Re: what grit for flex ball hone [Re: roadrunnerreds] #1548091
12/16/13 12:28 PM
12/16/13 12:28 PM
Penna
70satelliteguy Offline
Penna
Just went thru this.
http://www.summitracing.com/parts/brh-gbd41224/overview/
Call mfg. for grit recommendation. Summit has different selections than listed. They suggested the 240 grit for just honing the cylinders for new rings. Was easy but messy. Make sure you stay away from your wife's stuff while honing or you will get in trouble!!! Don't ask me how I know!
Mike
Re: what grit for flex ball hone [Re: 70satelliteguy] #1548092
12/16/13 12:44 PM
12/16/13 12:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike
I think this is more correct... it sound more like
the grit I used
