F Body help with oil accumulator needed #1547900
12/15/13 05:30 PM
12/15/13 05:30 PM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
I just bought a Moroso oil accumulator for the Aspen. I went to mount it on the passenger inner fender well in the engine bay and found out there is not enough room. If anyone has one on their F body would you please tell me where you mounted it.
Raul
Re: F Body help with oil accumulator needed [Re: Aspen7695] #1547901
12/15/13 07:31 PM
12/15/13 07:31 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
One thing to consider.......the reaction time will be longer with the longer line from the accumulator to it's pick up point.
You can mount them anywhere , but it's effectiveness will see a slight drop off if the distance gets too large.
No F body , but this fits under the hood.
Re: F Body help with oil accumulator needed [Re: tubtar] #1547902
12/15/13 09:56 PM
12/15/13 09:56 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The reaction time wont change with the length of the line. The accumulater is filled by the engines oil pump so the line has a solid column of oil in it. It will react instantly if pressurised properly. However a longer line will reduce its flow, so closer is better but only marginally.
Mount the tank where it best fits for you, closest to the engines feed.
Re: F Body help with oil accumulator needed [Re: Sport440] #1547903
12/16/13 05:36 AM
12/16/13 05:36 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Not sure if this helps but here is where mine is mounted on the Cuda, hard to see but it is in the inner fender area of the pass side. Left corner of picture.
Here is where we mounted it in the Valiant. Once again a bit hard to see but it is between the radiator and grille.
Re: F Body help with oil accumulator needed [Re: Al_Alguire] #1547904
12/16/13 01:09 PM
12/16/13 01:09 PM
Gilbert, AZ
Gilbert, AZ
Thanks Al. I never thought of mounting it verticality.
Raul
