What goes in this plug? 70 cuda #1547584
12/14/13 11:20 PM
12/14/13 11:20 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
I have one wire with a plug coming out of the firewall, in back of the brake booster, inboard side.
Nut sure what. Hooks up to this.
Any ideas?
AAR cuda 71 rag challenger
Re: What goes in this plug? 70 cuda [Re: 3406pac] #1547585
12/14/13 11:23 PM
12/14/13 11:23 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
There are 2 seperate wires, coming out of that area.
This is the lower wire, not sure what the upper one is but it is plugged in the forward side of the fuse block.
Re: What goes in this plug? 70 cuda [Re: 3406pac] #1547586
12/15/13 12:07 AM
12/15/13 12:07 AM
california
Mr D21 Offline
Mr D21  Offline
california
this one ?
Re: What goes in this plug? 70 cuda [Re: Mr D21] #1547587
12/15/13 12:49 AM
12/15/13 12:49 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Is it a 4speed car ??? It could be the safety switch wire from the clutch . . . it should go to the starter relay if so. You know, you have to depress the clutch pedal in order to start the car . . . according to FSM, should be a dark green wire
Cheers
Mark
Re: What goes in this plug? 70 cuda [Re: a12rag] #1547588
12/15/13 01:36 AM
12/15/13 01:36 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Go to mymopar.com and look int he tech section you can download a wire diagram for free. I got several of them and put them on a stick went to Target printing and had 11X17 copies made, mulitples for each car that way I can draw on them to trace circuit if I want to. It cost me $8 for about 3 copies on 4 cars.
I just wired mine, it's a 4 speed and if you post a picture of which one you have a question on I can probably tell you if not one of the smart guys can.
Good luck.
Careful, your character's showing!
Re: What goes in this plug? 70 cuda [Re: mopar346] #1547589
12/15/13 01:51 AM
12/15/13 01:51 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Dumb me , I forgot to add the picture.
And yes it is a 4 speed car.
Re: What goes in this plug? 70 cuda [Re: 3406pac] #1547590
12/15/13 03:06 AM
12/15/13 03:06 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Possibly green Road Lamp wire.
Re: What goes in this plug? 70 cuda [Re: 3406pac] #1547591
12/15/13 07:02 PM
12/15/13 07:02 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Thats the plug for the Ralley lights, a green wire goes in there.
Re: What goes in this plug? 70 cuda [Re: 67vertman] #1547592
12/16/13 02:39 PM
12/16/13 02:39 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
roadlamps and the back up light on the inst,panel.
Re: What goes in this plug? 70 cuda [Re: cuda-sweden] #1547593
12/16/13 03:23 PM
12/16/13 03:23 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 73 has a gray with black tracer wire coming out of the firewall in that location. It's the tach wire and goes to the - side of the coil.
