Will this rim fit correctly on a 1968 Charger?
#1547549
12/14/13 08:54 PM
12/14/13 08:54 PM
Posts: 397 Colorado
Hem1orange
Colorado
Re: Will this rim fit correctly on a 1968 Charger?
[Re: gtx6970]
#1547553
12/15/13 01:53 AM
12/15/13 01:53 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Had a friend that had the 8" on the front of his 69 RR. The wheels would rub the zerks in the ball joints. Had to run 1/8" spacers. Id run 7" on the front if it was mine..
I am truckless..
[Re: 340SHORTY]
#1547555
12/15/13 03:26 AM
12/15/13 03:26 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Are you sure you are remembering right and don't mean the wheel weights.
A 15" rim will not come close to a zerk. A 15x8 will come close to the edge of the upper control arm. With the 73-76 A-body disk brake swap, they do not rub with 15x8 rims with 4.5 backspacing. I've ran that setup for years.
But I did have a tire blowout on the freeway and I drove it to get off the freeway on the rim with a destroyed tire. That knocked a wheel weight off.
[Re: autoxcuda]
#1547556
12/15/13 03:32 AM
12/15/13 03:32 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I may be getting old but my memory is still good..
I am truckless..
