1970 B-body 4 speed question. Rod & #'s off attachment #1547277
12/13/13 11:55 PM
12/13/13 11:55 PM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I dont know what the piece's are called off the Transmission that the rods from the shifter attach too. One end has a round hole for the rod and the other a rectangle/square hole to attach to the tranny.
Now, I have a 70 Road Runner that needs those piece's and I guess there diffrent car to car so which number do I need to find for my car so that its correct and function's right.
Thanks!
Re: 1970 B-body 4 speed question. Rod & #'s off attachment [Re: High Impact] #1547278
12/14/13 12:02 AM
12/14/13 12:02 AM
MD
floyd Offline
floyd  Offline
MD
Re: 1970 B-body 4 speed question. Rod & #'s off attachment [Re: High Impact] #1547279
12/14/13 01:43 AM
12/14/13 01:43 AM
You need the shift levers, they need to match the brand and year of the shifter your using It wouldn't suprise me that there are some 4 speed parts like the shift levers that are the same for a few years like the B body shifters with bench seats using the standard OEM Hurst shifters. Mopar change the tailshaft cases, housings, in 1970 so they would fit both the B and E body cars so yours may be a one or two year only part
Re: 1970 B-body 4 speed question. Rod & #'s off attachment [Re: High Impact] #1547280
12/14/13 03:11 PM
12/14/13 03:11 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
If using a long pistol grip shifter you also need to use the right shifter mechanism & I think the rods maybe different also for the long pistol grip.
Re: 1970 B-body 4 speed question. Rod & #'s off attachment [Re: 493DRIVER] #1547281
12/14/13 05:29 PM
12/14/13 05:29 PM
Manistee, Michigan.
Manistee, Michigan.
I won the correct shifter last nite on E-bay with the rods (although Im not sure the rods are 70 b-body correct) The shifter assembly is correct with the right 7174 lever.
