Re: 9.25 diff/carrier question.
[Re: Haibach Boys]
#1546846
12/12/13 04:40 PM
12/12/13 04:40 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Throw the Auburn POS in the garbage and get a Detroit Tru Trc.. Its a much better unit and you will be a lot happier with it..
I am truckless..
[Re: Haibach Boys]
#1546847
12/12/13 10:58 PM
12/12/13 10:58 PM
Posts: 5,966 Greenville, PA
redraptor
Greenville, PA
I'm having an auburn limited slip and motive gears put in my 91 dodge with an 9.25 rear.. the guy set the pattern and its really nice damn near perfect...but the carrier (auburn unit) is rubbing the pinion...anyone have these problem with any of the componets. i did call auburn and they did suggest to verfy the part num on the housing, to make sure it wasnt boxed wrong.. other then that im at a lose for suggestions.
How high is the gear ratio for that to even happen? Secondly, this guy doesn't have a clue after setting up something so perfectly? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Polarapete]
#1546851
12/14/13 01:39 AM
12/14/13 01:39 AM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
It occurs to me that perhaps the reason for the interference is that the mechanic has set the pinion depth way too low and has achieved a "good pattern" by moving the ring gear adjusters out to their limits on one side and way retracted on the other. That would bring the carrier into the pinion
Not true. Pinion depth is dictated by the center line of the ring gear. If the pattern is correct the depth is set for that ring gear. If the right carrier is being used for the group ratio it is in it will not hit. If the wrong carrier is being used the correct pattern can be achieved but the clearances can be to close to the carrier.
[Re: NITROUSN]
#1546852
12/14/13 03:42 PM
12/14/13 03:42 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I think we are assuming the installer knows what he is doing and if that were the case there probably would be no issue to talk about ![](/ubbthreads/images/graemlins/Twocents.gif) As an amateur, I once spent several hours trying to get a Dana 60 setup right. I had a good pattern but the backlash was wrong, until I got the pinion depth right. Even with setup bearings it is a pain to assemble, check, disassemble, measure shims, reassemble, recheck ![](/ubbthreads/images/graemlins/frowwn.gif) Unless you stand over the guy and watch him put it together, we are only guessing here.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1546853
12/14/13 06:17 PM
12/14/13 06:17 PM
NITROUSN
This is also wrong. You don't adjust the pinion depth for backlash. If you have the correct pattern or close to you adjust the carrier to correct the backlash not the pinion. Pinion is set to the correct depth and bearing pre-load. At this step the pinion does not get changed. Then backlash is set with correct side bearing pre-load. Pattern verified and should be correct. The pinion adjustment will only give the correct pattern at one depth. 2-
[Re: Haibach Boys]
#1546854
12/14/13 06:25 PM
12/14/13 06:25 PM
NITROUSN
This can happen if the carrier is incorrect. As I recall the rwal trucks have a different carrier due to the rwal counting ring. Either way you could have a mismatch of parts causing the interference problem. The mopar style threaded adjusters offer a fast easy way to set the carrier up. If you were using shims you would most likely see one side with a big stack and none on the other immediately cluing you that something is not right.
[Re: NITROUSN]
#1546855
12/15/13 10:35 AM
12/15/13 10:35 AM
redraptor
Greenville, PA
I'll have to keep that in mind. I've set up several and never encountered this. I have only seen it in certain older GM 10 bolts.
