Re: Drilling and tapping Indy SB intake for bypass hose
[Re: SpareParts]
#1546502
12/12/13 09:31 PM
12/12/13 09:31 PM
Posts: 3,420 Toronto
mshred
Toronto
FWIW I ran a gutted T-stat with a bypass hose and no heater, I tried it once with no T-stat or restrictor and the water was moving too fast to actually cool the motor and it wanted to overheat. Stock 1/2 ton 80's ram radiator.
What do you run now?
Are you still running a bypass hose currently?
[Re: mshred]
#1546503
12/12/13 09:40 PM
12/12/13 09:40 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Gutted T-stat and a bypass hose. Works fine. Hardest part is keeping V belts on when the nitrous hits lol
[Re: MattW]
#1546505
12/12/13 09:45 PM
12/12/13 09:45 PM
SpareParts
Janesville, WI
There is an excellent cooling write up over on moparchats. He goes by 40ford over here. I would be more interested in pulling the water out of the rear of the intake and plumbing below your drilled out thermostat. Matt
That^^^^^ is something I have wanted to experiment with
[Re: sshemi]
#1546508
12/13/13 10:50 PM
12/13/13 10:50 PM
mshred
Toronto
If youre useing the heater box i see no reason to use the bypass. The heater box does the same thing. Im useing an electric water pump with stat and heater box no bypass.
Not running a heater box, which is why I asked this question in the first place
[Re: mshred]
#1546510
12/14/13 03:12 PM
12/14/13 03:12 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I run a 1/2" bypass hose with a t-stat and a electric pump to keep water moving when the stat is closed. You want the water to circulate by the t-stat so it will see the real water temp.
I drilled and tapped the manifold in the stock location and ran the hose to the unused port on the suction side of my Meziere pump with a reducing bushing and a hose fitting. Works well for me.
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#1546511
12/14/13 07:57 PM
12/14/13 07:57 PM
mshred
Toronto
Have a pic of this setup?
[Re: mshred]
#1546512
12/15/13 12:31 AM
12/15/13 12:31 AM
Triple Threat
Renton Washington
I pulled this out of my car years ago and began running the car with nothing at all. I drilled the holes in it out of boredom one day. Its still sitting in the top of my tool box.
[Re: mshred]
#1546514
12/15/13 12:41 PM
12/15/13 12:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That basically what I run... those holes look bigger than what I run(I run 6 holes 1/8") just so the water flows and not dead heading the pump
[Re: Just-a-dart]
#1546517
12/16/13 02:12 AM
12/16/13 02:12 AM
mshred
Toronto
Here is my set up
Thanks!
Makes me feel like I should run a bypass hose, especially if I am not running a heater...I really dont want to chance hot spots in the motor
