Re: Anyone going total NO E racing ? ...
[Re: dOc …]
#1546390
12/11/13 02:56 PM
12/11/13 02:56 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My sons 10.50 small-block Duster is non-electronics except for his air shifter. He is a better foot braker than he is if he uses his trans-brake.
[Re: pittsburghracer]
#1546391
12/11/13 03:04 PM
12/11/13 03:04 PM
Triple Threat
Renton Washington
I have a transbrake/2 step and rarely ever use it. Usually footbrake with no 2 step.
[Re: dOc …]
#1546395
12/11/13 06:13 PM
12/11/13 06:13 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
now... where's that dual point distributor? probly in the attic, maybe in the basement
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: oldiron]
#1546396
12/11/13 08:51 PM
12/11/13 08:51 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I had all the electronics in my car for a long time,(and won races with them) but took them out in the middle of the season 2009. I also swap feet now, no trans brake, no two step, no air shifter, no nothing. Best move I ever made. And the closest thing to a dragster in my class is a Mopar powered roadster.
Brian Dunnigan
[Re: dOc …]
#1546397
12/11/13 09:06 PM
12/11/13 09:06 PM
Posts: 9,883 MI, usa
dvw
MI, usa
.... no electronics at all ... not even a trans brake ?? ....and BTW ... does anyone know if there is a "zap-gun" that will fugg-up a E car ?
I have no problem running against the E guys. I foot brake, no 2 step, shift with a push button,10.5 tires at 9.30@147. Best bracket car I've ever had. Doug
[Re: dvw]
#1546398
12/11/13 09:10 PM
12/11/13 09:10 PM
Quicktree
[Re: dOc …]
#1546401
12/11/13 10:21 PM
12/11/13 10:21 PM
Quicktree
you don't like them don't race in that class, I think i'll die of old age before I see you racing why would you even worry about them? if your good enough it shouldn't be an issue.
[Re: dOc …]
#1546402
12/11/13 11:18 PM
12/11/13 11:18 PM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
A portable EMP (Electro Magnetic Pulse) device would do the trick. But...doing a google search on it may get you on the terrorism watch list.
[Re: oldiron]
#1546403
12/11/13 11:42 PM
12/11/13 11:42 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
I was thinking the same thing...
No E for me. Had 2 step, delay box and trans brake in my last car. Too many variables. Now nothing but a throttle and brake pedal. More fun! ![](/ubbthreads/images/graemlins/biggrin.gif)
