compression: point of deminishing returns #1545747
12/09/13 03:29 PM
12/09/13 03:29 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
with a 4" stroke sb what do you think would be the point of diminishing returns?
I once read in the mopar journal that 13:1 had the most advantage. beyond that gains were very small.
Re: compression: point of deminishing returns [Re: mopar dave] #1545748
12/09/13 04:57 PM
12/09/13 04:57 PM
Delray beach, Florida
P
Performance Only Offline
P
There's no one size fits all. It's totally dependent on the rest of the combination.
machine shop owner and engine builder
Re: compression: point of deminishing returns [Re: Performance Only] #1545749
12/10/13 12:54 AM
12/10/13 12:54 AM
What fuel, what appication, drag racing, street and strip, roundy round racing,N/A, power adder or no power adder and so on
Re: compression: point of deminishing returns [Re: Cab_Burge] #1545750
12/10/13 01:02 AM
12/10/13 01:02 AM
Mt Morris Michigan
Mt Morris Michigan
4" stroke 4" bore small block using indy 230cc head and indy intake with 1100 dom, .700 lift roller cam. drag race n/a
Re: compression: point of deminishing returns [Re: mopar dave] #1545751
12/10/13 05:06 AM
12/10/13 05:06 AM
Which type of fuel, race gas, alcholol or E85? If race gas exactly which brand and octane number, IE VPC10,C11,C12, Rocket 110 and so on? You really need to settle on the fuel and octane before choosing the compression ratio
Re: compression: point of deminishing returns [Re: Cab_Burge] #1545752
12/10/13 09:29 AM
12/10/13 09:29 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
The curve of a hemi piston slows down the burning of fuel. Many ran that ran 13.5-1 changed to 12.5 which allowed the use of 110 octane instead of 112or 114. Lower octane burns faster then higher grades .
home of the
Sox and Martin Hemi Duster
Re: compression: point of deminishing returns [Re: HEMIFRED] #1545753
12/10/13 09:36 AM
12/10/13 09:36 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Many comp engines are built at 16.5:1 compression. Like said before it depends on what gas you want to run. You will be wanting 116 or better fuel when you get over 15:1.
My 421 W8 was 16.5:1 and it preferred 118NOS fuel which was illegal in the class I ran.
Leon
Re: compression: point of deminishing returns [Re: Cab_Burge] #1545754
12/10/13 10:26 AM
12/10/13 10:26 AM
Mt Morris Michigan
Mt Morris Michigan
k, I guess I was doing that backwards. thought I could pick the cam and fuel to match the compression. 110 race fuel (gas)
Re: compression: point of deminishing returns [Re: mopar dave] #1545755
12/10/13 11:51 AM
12/10/13 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your static compression is just a number that doesnt
mean a whole lot... when the valve closes is when
it start the compression cycle... my 14.1:1 engine
has 170 cranking pressure
Re: compression: point of deminishing returns [Re: mopar dave] #1545756
12/10/13 11:57 AM
12/10/13 11:57 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Based on the ideal cycle, the plateau starts to occur in the teens. But this is based on an ideal cycle, not taking into account fuel, operating conditions, etc. But it gives you the general idea that the substantial gains are already realized once you get into the race gas region.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: compression: point of deminishing returns [Re: OUTLAWD] #1545757
12/10/13 12:33 PM
12/10/13 12:33 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
dave......this might give you a little example of cam/compression change had on my 4 inch w5 combo...
I went from a 260/266 flat tappet cam 416 with 11.8 compression w5 headed combo that ran a best ever of 10.38 at 129 and change.
Swapped in a 422 shortblock, that ended up being 13.3 compression, and added a 700 lift roller that was 273/280@ 50 cam shaft.
same heads, headers, carb, intake, gears and convertor. So pretty much the only real effective changes was going from 4.07 bore to 4.100 bore, the compression bump and the bigger roller over the smaller flat tappet. Rest of the combo remained the same.
Best with those changes was 9.85 at about 135. So about 5.5 tenths and 5 or 6 mph.
The new shortblock of course was fresh, and had 043 ring pack, but it yielded a significant difference. Picked up about a full tenth in 60 foot, suspension remained identical, as did tires/wheels etc.
Hope this might help.
should probably also add, current owner of car took off 150 pounds,down to 3200 pounds freshened shortblock again, went to a more aggressive roller that is 276/282 I believe,same lift or close, and bumped compression to just over 14 to 1, and picked up additional 5 mph and 2 tenths, with everything else unchanged..same gears,tranny convertor, carb, intake, headers, suspension etc. The car really seemed to like the much more aggressive profile of the camshaft, over the quite mild profile I ran that was easy on springs and was somewhat streetable. All three cams, the flat tappet and the two rollers were all specc'ed by Dwayne Porter.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: compression: point of deminishing returns [Re: OUTLAWD] #1545758
12/10/13 01:57 PM
12/10/13 01:57 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Seems to me a graph with more graduations is needed to prove or disprove your point. It appears to me there are noticeable benefits all the way up to say 15:1. Even after that there are benefits all the way across the scale.
I can only speak from my own experience. I had a combo that was too high on compression for NOS. I also ran it some NA. I swapped out the pistons for dish pistons. Nothing else changed went from 17.5:1 to 14:1. The engine was more forgiving with NOS, but lost all it's might off the starting line NA. So after talking to a guru I started thinning the head gasket. I quit when it reached 14.8:1 as the pistons were showing they were close to the head during operation.
It is easy to make compression with the stroker small blocks. You can go too far. For basic fuels up to 112 I would stay below 14:1. Then it just depends on how well the combustion chamber is and your camshaft.
Leon
Re: compression: point of deminishing returns [Re: mopar dave] #1545759
12/10/13 02:19 PM
12/10/13 02:19 PM
AndyF Offline
AndyF  Offline
For a race engine you'll want the most compression possible without hurting power. Sometimes a large dome will reduce power or deep valve pockets will reduce power.
Max power on race gas would be 16:1 compression with a flat top piston but you rarely get that lucky.
Re: compression: point of deminishing returns [Re: AndyF] #1545760
12/10/13 03:50 PM
12/10/13 03:50 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I prefer the most compression up to 16.5-1 I can get, without a dome, with a .050 head gasket. That said, I usually need a small dome. Stroke has everything to do with it, and I have 4.5 and 4.75.
Re: compression: point of deminishing returns [Re: AndyF] #1545761
12/10/13 03:52 PM
12/10/13 03:52 PM
Mt Morris Michigan
Mt Morris Michigan
that's what i'm really tryin to figure out. I know there is a point the extra compression is not worth the little gain. the engine has to work harder driving the next piston up on compression. don't want to use exspensive race fuel neither. like to run it on 110. looks like 16:1 is the platue as far as diminishing returns. thanks
Re: compression: point of deminishing returns [Re: mopar dave] #1545762
12/10/13 06:28 PM
12/10/13 06:28 PM
Az
Crizila Offline
Crizila  Offline
Az
I think what you are really asking is when does the benefit of a higher CR exceed the $ cost associated with the initial build and maintenance. You can't just look at a curve that only represents power gain wit a higher CR. You have to look at the intersecting point between the power gain curve and the cost curve ( includes build costs and some amount of breakage / repair costs ). So how much $ do you have to spend on the $ curve? Initial build $ should be easy enough to get. Breakage side will be a guess - but there will be some and it will go up with the CR. If you want to use fuel ( 110 )as your limiting factor: When the max wedge first came out in 63, it was available with 13.5:1 Cr. In 64 they dropped it to 12.5:1. Same HP rating. Just about everyone ran on Sunoco 110 gas. Don't forget the most important rule in drag racing - getting from point A to point B - consistently.
Fastest 300
Re: compression: point of deminishing returns [Re: AndyF] #1545763
12/10/13 07:04 PM
12/10/13 07:04 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Andy, I might just agree with that. My 421 W8 engine was built to run Pro Comp. I listened to everything Tim Davis suggested. After all he was flying with his car and several customers. My engine was built 16.5:1 with flat tops. The valve pockets were cut just enough to get by. Well, actually not enough, it blew up. The engine ran far better with Torco 118NOS than it did with any other fuel I tried. The class limited us to C19 C21 and C25. All good fuel but the car performed weak early in the run.
Always wanted to try a small dish that matched the cylinder head just to see what the difference would be. We ran a very tight piston to head clearance also.
Leon
Re: compression: point of deminishing returns [Re: mopar dave] #1545764
12/10/13 07:26 PM
12/10/13 07:26 PM
Macomb Michigan
65 Belv A990 Offline
Macomb Michigan
You also have to factor in the value of the increased gains vs. the diminishing thickness to your wallet for fuel. If you plan to race a lot, factor in the cost of these expensive higher octane slower burning fuels needed to support that extra compression. Going higher than what the average 110 octane fuel will support (13.0:1 or so with aluminum heads) will add 25-30% or more to your fuel budget which is constant and not a one-time expense like the initial build.
MoPower..... Better to be a racer for a moment than a spectator for a lifetime.
Re: compression: point of deminishing returns [Re: mopar dave] #1545765
12/10/13 08:33 PM
12/10/13 08:33 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
If you want to stay with Sonoco 110, 13.5-1 sounds like the right compression and you should be able to use a flat top depending on cc of the combustion chamber.
Re: compression: point of deminishing returns [Re: camastomcat] #1545766
12/10/13 10:07 PM
12/10/13 10:07 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
David Vizard's book "how to build Horsepower" had an inverted triangle chart that gave you the 'order of magnitude' from old to new CR...I have it somewhere but from say (for example) 9 to 11 was much higher percentage than from 11 to 13 which to some extent is mathematical 11/9ths is a higher proportional increase than 13/11ths. The higher you went the lower the gain, while it's true as you increase the pressure you also increase the speed of the flame travel, but at some point you hit diminishing returns and design limits of the engine itself.
WIZE
In Car:
