? Back fire on deceleration open headers #1545392
12/08/13 09:00 PM
12/08/13 09:00 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
My new engine had no issue's on the Dyno , put it in the car and free rev the engine it backfires out of the headers. It seem to do it more on the left bank then the right. Would poor header sealing to the heads cause this? by pulling cold air into the header tube? Or is something else?
Switched to the dark side...
Re: ? Back fire on deceleration open headers [Re: JSR1485] #1545393
12/08/13 09:34 PM
12/08/13 09:34 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
mine did that after I switched to E-85 and the first thing a couple of guys told me was "you got a header leak" pulled them off the car this winter and did find some of the slip tubes were a little loose so maybe there is somthing to it.
Re: ? Back fire on deceleration open headers [Re: JSR1485] #1545394
12/08/13 09:37 PM
12/08/13 09:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Headers would be the first place to look
Re: ? Back fire on deceleration open headers [Re: MR_P_BODY] #1545395
12/08/13 09:42 PM
12/08/13 09:42 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I will have try to reseal them, cannot find correct header gaskets.
Re: ? Back fire on deceleration open headers [Re: MR_P_BODY] #1545396
12/08/13 10:47 PM
12/08/13 10:47 PM
My Cuda started doing that after racing it part of the year,big tube headers on a set of eddy RPM heads. I had let one of the end header bolts get loose and it ended up blowing the side of that gasket out Check for warp flanges also
Re: ? Back fire on deceleration open headers [Re: JSR1485] #1545397
12/09/13 01:26 AM
12/09/13 01:26 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Mine was doing that as well. I found a pretty good size crack on the bottom of one of the tubes where it crosses over the rear one. Welded it up and no more backfires.
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
