Drive as you would a NEW ENGINE Card location? #1545346
12/08/13 07:02 PM
12/08/13 07:02 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
My friend recently purchased a Drive as you would a NEW ENGINE card (from Legendary). He is not clear on the exact location of where the card should be placed in the vehicle. Any thoughts on the correct location where the card should be located? Turn signal, rearview mirror? I attached a photo for reference.
Re: Drive as you would a NEW ENGINE Card location? [Re: vinnyd76] #1545347
12/08/13 10:05 PM
12/08/13 10:05 PM
OT but definitely pertinent is "breakin secrets" at www.mototuneusa.com. Consider this a BTT for ya
Re: Drive as you would a NEW ENGINE Card location? [Re: RapidRobert] #1545348
12/09/13 12:05 PM
12/09/13 12:05 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Looks like it has holes for a string or wire to fasten to the shift lever or steering wheel??
Joe
