Roll cage knee bar
#1544961
12/07/13 09:28 PM
12/07/13 09:28 PM
Posts: 4,085 Mo.
racerx
Mo.
Re: Roll cage knee bar
[Re: MR_P_BODY]
#1544963
12/07/13 09:52 PM
12/07/13 09:52 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
When you cap and welded. I assume you mean if the intersect the A-pilar bar. Yes they can be cap welded. The proper name, if I understand correctly is the dash bar. If the bar intersects it has to be 1 5/8" diameter. It can be 1 1/4" if it just welds onto the A-pilar bars.
Leon
[Re: racerx]
#1544966
12/08/13 02:31 PM
12/08/13 02:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thaxs I've been looking at some of the pro-built cage here and over on the bullet and notice that the knee/dash bars that were intersected were welded to the kick panels and did not know if it were an NHRA thing or what................
The more attachment points the better but IF you have flex it will apply it to the body if its attached at that point ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1544967
12/08/13 06:40 PM
12/08/13 06:40 PM
Leon441
Lynchburg, VA
If your cage is tied to the rockers and or stock sub frames I would tie the dash bar to the A-pillar sheet metal as well.
If the body is not tied well such as cars with no floors and basically the body just hangs by the tubs and sheet metal then I would not.
If it is somewhere between I probably would not either.
Leon
[Re: racerx]
#1544970
12/10/13 02:35 PM
12/10/13 02:35 PM
Posts: 4,590 Motor City
6PKRTSE
Motor City
I posted in the cage post this picture. This is another picture if this helps.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1544972
12/11/13 09:39 AM
12/11/13 09:39 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
If that upper most bar is the piller bar then it will not pass NHRA SFI specs it must continue to the floor or have a bar directly under it that continues to the attachment point. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: 6PKRTSE]
#1544974
12/11/13 03:35 PM
12/11/13 03:35 PM
B G Racing
Eighty Four, PA
It passed & they commented how they liked it tied into the kick panels. 25.5 sticker is good until 2014.
That's great they passed it. ![](/ubbthreads/images/graemlins/bow.gif)
[Re: B G Racing]
#1544975
12/11/13 03:39 PM
12/11/13 03:39 PM
6PKRTSE
Motor City
I have seen 3 other cars done this way & they were all 25.5 certed before mine. I got the idea from Stef's old Challenger pictures & his also passed & had a 25.5 cert. We just copied it.
[Re: 6PKRTSE]
#1544976
12/11/13 03:47 PM
12/11/13 03:47 PM
MR_P_BODY
I think the only reason it passed is because its welded to the kick panel area... you changed the load path with the down bar inward... but being its welded to the KP and its a short distance... if that knee bar was hanging out in space it wouldnt have passed ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1544977
12/11/13 04:24 PM
12/11/13 04:24 PM
B G Racing
Eighty Four, PA
The reason I questioned it is according to SFI any of the main cage structure,hoops,piller bars,down bars and side bars must be in a continious plane or if intersected must have a continious plane bar at the intersection continueing to the attachment point on the floor or frame.I have never seen mention of attaching to the kick panel.Usually any attachment to sheet metal a 6x6 plate with 100% weld is required,but is only noted for unibody cars at the floor.If the firewall was unaltered or all steel then the knee bar is not required.Maybe that is why it was passed. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 6PKRTSE]
#1544978
12/11/13 06:05 PM
12/11/13 06:05 PM
Posts: 3,877 Smyrna, South Carolina
STEFF
Not sure if yours is just butted/welded to the inner reinforcing plate or not. But, mine passed thru both sides of the factory sheetmetal in the kick area, and there were reinforcing plates on the inside like you have shown and on the outside where the door would be. You could look thru the tube from the outside of the car with the door open. Like yours, there were no issues with the A-Pillar Bar being two pieces at cert time. Personally I think it's better than the one piece bar as the car is gusseted from side to side, in case of any side impact.
[Re: 6PKRTSE]
#1544979
12/22/13 01:59 PM
12/22/13 01:59 PM
Posts: 4,085 Mo.
racerx
Mo.
Does the cage gusset need to be 118"thick also?Or is there a limit?.........Thax ![](/ubbthreads/images/graemlins/wave.gif)
