'99 Ram, anything to look out for? #1544567
12/07/13 04:20 AM
12/07/13 04:20 AM
Sarcoxie, MO, USA
MoPar Jamie Offline OP
Sarcoxie, MO, USA
Hey all,
The 5 spd truck didnt work out because of a title issue, but he let me have at a '99 truck instead AND I have been able to work on it in a heated shop.
The truck is a basic '99 1500 2wd long box. 318/auto Overall, other than the box its not too bad off. Some J.O. took the rt. taillight when it was sitting behind his shop but otherwise it was complete.
The issue was that some kids of a previous owner took off in it with a leaky radiator and locked the motor up. So I got a motor in with the deal (one I owned previously, ironically).
So, as it its now I have to drop on the '99 intake ('94 motor) and start stringing wires, brackets, etc.
So, are there any issues to look out for on these trucks? Do the tranny lines have check balls in them on '99s?
I'm just looking out for the basics really, as I plan to drive this thing and use it to help move 3 hours away.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: '99 Ram, anything to look out for? [Re: MoPar Jamie] #1544568
12/07/13 11:50 AM
12/07/13 11:50 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
yes ,have tranny check ball,also reseal the intake belly pan on bottom of intake.hughes has a nice fix,everything else plug n play
Re: '99 Ram, anything to look out for? [Re: d-150] #1544569
12/07/13 02:35 PM
12/07/13 02:35 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You will also have to use the 99 flexplate on the 94 motor for the converter bolts to line up. 96 and up have a 90 degree bolt pattern. Earlier models have one offset hole for the converter bolts.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: '99 Ram, anything to look out for? [Re: 71yelladustr] #1544570
12/07/13 03:28 PM
12/07/13 03:28 PM
Sarcoxie, MO, USA
Sarcoxie, MO, USA
Yep I swapped flexplates out before I did anything. I am replacing the valley pan gasket just in case before the intake goes on. Where is the check ball located? I thought the were 86'd after '98, but I wasnt sure.
- MoPar Jamie
1972 Fury III 4dr
