looking for pics of jesel small block belt drive #1544292
12/05/13 10:12 PM
12/05/13 10:12 PM
Long Island, New York
W
W7 Duster Offline OP
W
Looking for pics of jesel small block belt drive with motor plate, front distributor, and remote water pump. Replacing my current engine that uses stock style water pump and motor plate. Wondering about spacers and water fittings. Thanks
Re: looking for pics of jesel small block belt drive [Re: W7 Duster] #1544293
12/05/13 11:33 PM
12/05/13 11:33 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Chuck i don't have pics,but i actually have the webber belt drive and front distributor set up.I bought it from Dave Webber at modern muscle.If you want to see it in person just lmk when you'll be @ Johns and ill show it to ya.Merry Xmas also.
Re: looking for pics of jesel small block belt drive [Re: W7 Duster] #1544294
12/05/13 11:51 PM
12/05/13 11:51 PM
Out West
408strokerdart Offline
Out West
I have the exact set-up you are describing....not sure what I have for pics on my computer. I also have Star Vac pump and Peterson Wet sump as well as my coil mounted on the front motor plate. I will see what I can find for pictures.
Couple of different directions you can go with your plate set up. No need for the special water pump spacers if you use a remote pump and push water into the core plugs instead.
Re: looking for pics of jesel small block belt drive [Re: W7 Duster] #1544295
12/06/13 12:03 AM
12/06/13 12:03 AM
AndyF Offline
AndyF  Offline
I make remote water pump adapter blocks for SB Mopar engines. These blocks should work with a Jesel belt drive as long as the standard bolt pattern is being used.
Re: looking for pics of jesel small block belt drive [Re: AndyF] #1544296
12/06/13 01:16 AM
12/06/13 01:16 AM
Out West
Out West
Tall deck or short deck block?
Re: looking for pics of jesel small block belt drive [Re: 408strokerdart] #1544297
12/06/13 09:10 AM
12/06/13 09:10 AM
W
W
9.20 deck. I like that set up! Did you make the motor plate. Is the motor plate the same space out as the stock timing case cover?
Re: looking for pics of jesel small block belt drive [Re: W7 Duster] #1544298
12/06/13 01:26 PM
12/06/13 01:26 PM
Out West
Out West
I can't speak for Andy, but I don't think his set up works for short deck blocks as the upper water pump hole is in a different location. If you are changing from a timing cover set up to a jesel belt drive you will need some special spacers to offset the motor plate the specific difference between the two. I have been thru this so it is something I an very familiar with.
Re: looking for pics of jesel small block belt drive [Re: 408strokerdart] #1544299
12/06/13 02:07 PM
12/06/13 02:07 PM
408Dust Offline
408Dust  Offline
9.200
Re: looking for pics of jesel small block belt drive [Re: W7 Duster] #1544300
12/06/13 02:46 PM
12/06/13 02:46 PM
AndyF Offline
AndyF  Offline
Sorry, the stuff I make is all for the standard deck height blocks. I have the CAD files for the race blocks but I haven't made any parts yet for those blocks.
Re: looking for pics of jesel small block belt drive [Re: AndyF] #1544301
12/06/13 04:03 PM
12/06/13 04:03 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The heads choice will make a difference in coolant routing. I have a maziere remote pump and shove water into the block through the center core plugs , then out of the W-9's via six lines to an expansion tank / thermostat housing. Not pretty , but it works on paper.
This is also a Weber drive.
Re: looking for pics of jesel small block belt drive [Re: tubtar] #1544302
12/06/13 10:58 PM
12/06/13 10:58 PM
W
W
Like anything else, you change one thing you change 100 things! Thanks guys! Just need to see where everything lays out!
Re: looking for pics of jesel small block belt drive [Re: W7 Duster] #1544303
12/07/13 11:02 AM
12/07/13 11:02 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I had spacers on my 421 that adapted from the low deck pattern to the tall deck pattern. Then a mopar water pump bolted right up.
Tim Davis of Indy made the spacers. They were the same thickness as the stock timing cover. It would not be rocket science if you could give someone the pattern of your 9.2 deck block and a stock water pump. Any CNC shop can make this. The cost is much less if you can fin someone who has already done the work. I could probably make some fairly easy with my cheasy XY table and cutter in my drill press. Someone like Andy or Ritter or Davis could sell you some cheaper.
Leon
Re: looking for pics of jesel small block belt drive [Re: Leon441] #1544304
12/07/13 09:47 PM
12/07/13 09:47 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Mezier, Ritter, Weber.... none have spacers. I opted the the "shade tree" look and cut the top off an Arrow timing cover I procured. If Brian does a run of spacers i indicated to him I'm interested.... until then this will allow my W8 9.200 mill to bolt up in place of my iron MP headed 360.
Re: looking for pics of jesel small block belt drive [Re: J_BODY] #1544305
12/07/13 10:13 PM
12/07/13 10:13 PM
Out West
Out West
I'm on it. Shouldn't be to long.
Re: looking for pics of jesel small block belt drive [Re: 408strokerdart] #1544306
12/07/13 10:32 PM
12/07/13 10:32 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....figured if I posted up a pict you'd not be able to stand something so hideous on such a beautiful combo!
...it took me two days to finally cut that cover! I wasn't comfortable doing that to a perfectly good part. I will add, to those even remotely interested, I did have to have the radius on the cover welded up to fill in a gap where the waterpump mates to. Just filed it flat by hand.
Re: looking for pics of jesel small block belt drive [Re: J_BODY] #1544307
12/07/13 11:22 PM
12/07/13 11:22 PM
Out West
Out West
No offense, but that is ugly. I got something to fix 'yall up.
Re: looking for pics of jesel small block belt drive [Re: 408strokerdart] #1544308
12/07/13 11:42 PM
12/07/13 11:42 PM
oregon
greendart408 Offline
oregon
Brian,
Do you have pics of the spacers you are making, I might be interested in a set also.
Re: looking for pics of jesel small block belt drive [Re: greendart408] #1544309
12/08/13 01:58 AM
12/08/13 01:58 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I used this pump........no worries about timing cover , spacers etc.
Ryan at Shady Dell had the aluminum core plugs that are threaded for 3/4 NPT and went with -12 line into each center core plug.
One benefit was that I had a lot of options for where to locate it.
I don't have a pic yet , but it is just below the outlet on the radiator and maybe 8" back , so a short 1 3/4 "L" of radiator hose was all I needed to get it fed.
The 55 GPM might be a bit generous , but the stat will help there I think. I am pretty sure they make a 35 GPM in the same configuration.
http://www.meziere.com/ps-1134-1102-wp316s.aspx
Re: looking for pics of jesel small block belt drive [Re: tubtar] #1544310
12/08/13 02:13 AM
12/08/13 02:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
you know what they say about hindsite John.... I don't know why I was so hell bent on using the small block mezier pump. Even the water pump on my big block in our old Mirada was a divorced unit (shogun). Guess I was blinded by having something familiar to the previous small block in our Duster. Either way....forward we go. I appreciate your input on my build and providing me with that motor plate you sent me.
Re: looking for pics of jesel small block belt drive [Re: J_BODY] #1544311
12/08/13 11:39 AM
12/08/13 11:39 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Bob Ette, Arch Engineering Integration made me both a motor plate and spacers to use my Meziere pump with a 9.00 deck R3 block. However I have a Weber belt drive.
Bill
