Re: Troubleshooting temp issue
[Re: Pacnorthcuda]
#1544166
12/07/13 03:11 AM
12/07/13 03:11 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Those plugs look like its running real lean..You want them to be slightly tan..
I am truckless..
[Re: cal_gecko]
#1544170
12/07/13 11:36 AM
12/07/13 11:36 AM
Posts: 1,589 My Garage / Museum
idrivevintage
Chrysler Plant
Chrysler Plant
My Garage / Museum
sorry guys.. I misreported on the type of fan... it's an OEM fan .. and it's in the shroud, so it should be pulling plenty of air through.
Is it a clutch type or a direct blade? Also I believe you want the blades of the fan to sit about 3/4 of the way into the shroud...is that where yours are ![](/ubbthreads/images/graemlins/scope.gif)
[Re: cal_gecko]
#1544173
12/07/13 01:30 PM
12/07/13 01:30 PM
RapidRobert
It appears that the fan needs to be spaced farther into the shroud which is needed at lower speeds but is a non issue for it to be overheating at 50MPH. Something else is going on
[Re: RapidRobert]
#1544174
12/07/13 02:06 PM
12/07/13 02:06 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
I'm suspecting a blockage in the radiator. I'll check the thermostat today.. and if that doesn't work, I'll disconnect the hoses on the radiator, and see if I can run water through it with the garden hose. I guess that should tell me if there's a blockage.
It does sound like I may be running lean too .. which is surprising because the exhaust is pretty pungent .. but I'll need to look up how to richen the mixture on the Edelbrock carb.
[Re: RapidRobert]
#1544176
12/07/13 03:13 PM
12/07/13 03:13 PM
cal_gecko
Sacramento, CA
Actually a lean misfire can make it smell gassy as the mixture does not ignite in that cyl or random cyls & goes out the tailpipe. Take off the metering rod caps & remove the metering rod piston/rod assys & put something under the spring(s) to block them up then replace the assys & take her out for a spin & you'll be on the "power" step which is way richer
I'll take a look and see if I can visualize what you're talking about a bit better. Not sure what "something" would be that would be appropriate to put under the springs to block them up .. .i'll see ..
[Re: cal_gecko]
#1544180
12/07/13 06:01 PM
12/07/13 06:01 PM
Challenger 1
Cincinnati, Ohio
Never mind, wow ...I guess you don't look in there much?
