Page 2 of 4 1 2 3 4
Re: Troubleshooting temp issue [Re: cal_gecko] #1544161
12/07/13 01:05 AM
12/07/13 01:05 AM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
3
Re: Troubleshooting temp issue [Re: cal_gecko] #1544162
12/07/13 01:07 AM
12/07/13 01:07 AM
Sacramento, CA
Sacramento, CA
Tomorrow I'll do some further checking and temp measurements per your advice (bottom of radiator versus top, checking the lower hose (I did put a spring in it last year when I realized it was collapsing when it ran), and I may just pull the thermostat out to see how warm it runs without one for a bit...
And to answer the question about how I was driving it.. I was doing about 50mph on long open stretches, with outside air around 35 degrees F.
Re: Troubleshooting temp issue [Re: cal_gecko] #1544163
12/07/13 01:29 AM
12/07/13 01:29 AM
My , the radiator (assuming the stat is opening all the way).
Re: Troubleshooting temp issue [Re: RapidRobert] #1544164
12/07/13 01:31 AM
12/07/13 01:31 AM
Sacramento, CA
Sacramento, CA
Just checked timing.. about 25 degrees advance at idle, and 42 at about 2800-3000 rpm
Re: Troubleshooting temp issue [Re: cal_gecko] #1544165
12/07/13 02:01 AM
12/07/13 02:01 AM
Kirkland, Washington
Pacnorthcuda Offline
Your timing numbers are high. Back them off to 18 at idle, which will net you 35 total, which is much more reasonable. Don't know if that will help the overheating much though. :twocents
I am assuming we are talking about mechanical advance only.........and now that I think about it I think my assumption is wrong.......
Re: Troubleshooting temp issue [Re: Pacnorthcuda] #1544166
12/07/13 03:11 AM
12/07/13 03:11 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Those plugs look like its running real lean..You want them to be slightly tan..
I am truckless..
Re: Troubleshooting temp issue [Re: 340SHORTY] #1544167
12/07/13 05:10 AM
12/07/13 05:10 AM
Sacramento, CA
Sacramento, CA
realized that when I was checking timing, I didn't disconnect the vacuum advance from the distributor.
I'll do some research on how to make the mixture richer on the carb (Edelbrock Performer 600cfm)
Which sucks, because the car's getting 8 mpg as it is.. I'm guessing if I go richer, it'll get worse!
Re: Troubleshooting temp issue [Re: cal_gecko] #1544168
12/07/13 09:58 AM
12/07/13 09:58 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why do you have vacuum advance at idle?
LEan misfire can cause poor mileage too.
Don't be the exception.
Re: Troubleshooting temp issue [Re: Supercuda] #1544169
12/07/13 10:51 AM
12/07/13 10:51 AM
IN
ahy Offline
ahy  Offline
IN
If its overheating at 35 F with decent fan something is seriously out of whack.
As a useful and low cost diagnostic, suggest you remove the T stat and run it. As mentioned above, run it with the cap off for a while and watch for coolant flow in the top tank.
If removing the stat improves temps it is a bad stat. If you don't see coolant flow either the radiator is seriously blocked or the water pump is fubar. Its rare, but the blades can rust off the pump.
If you suspect the radiator, you can pull it and get it checked out at a rad shop.
Also, mild "at home" flush of the block and radiator wouldn't hurt. I rig up an adapter to go from garden hose to radiator hose. 1 1/4" or 1 1/2" PVC pipe matches rad hose diameter pretty well. With stat removed, rig it up to flush the block or radiator.
Re: Troubleshooting temp issue [Re: cal_gecko] #1544170
12/07/13 11:36 AM
12/07/13 11:36 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
sorry guys.. I misreported on the type of fan... it's an OEM fan .. and it's in the shroud, so it should be pulling plenty of air through.
Is it a clutch type or a direct blade? Also I believe you want the blades of the fan to sit about 3/4 of the way into the shroud...is that where yours are
Re: Troubleshooting temp issue [Re: idrivevintage] #1544171
12/07/13 12:53 PM
12/07/13 12:53 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
where are you at with this?let us know
Re: Troubleshooting temp issue [Re: mcmopars] #1544172
12/07/13 01:24 PM
12/07/13 01:24 PM
Sacramento, CA
Sacramento, CA
I'll pull the thermostat out today (crap, I don't know if I have any gaskets sitting around... might have to run to the store to get one) and test that...
for reference, here's a top view of the rad/fan/shround.. it's a fixed blade fan.
Re: Troubleshooting temp issue [Re: cal_gecko] #1544173
12/07/13 01:30 PM
12/07/13 01:30 PM
It appears that the fan needs to be spaced farther into the shroud which is needed at lower speeds but is a non issue for it to be overheating at 50MPH. Something else is going on
Re: Troubleshooting temp issue [Re: RapidRobert] #1544174
12/07/13 02:06 PM
12/07/13 02:06 PM
Sacramento, CA
Sacramento, CA
I'm suspecting a blockage in the radiator. I'll check the thermostat today.. and if that doesn't work, I'll disconnect the hoses on the radiator, and see if I can run water through it with the garden hose. I guess that should tell me if there's a blockage.
It does sound like I may be running lean too .. which is surprising because the exhaust is pretty pungent .. but I'll need to look up how to richen the mixture on the Edelbrock carb.
Re: Troubleshooting temp issue [Re: cal_gecko] #1544175
12/07/13 02:14 PM
12/07/13 02:14 PM
Actually a lean misfire can make it smell gassy as the mixture does not ignite in that cyl or random cyls & goes out the tailpipe. Take off the metering rod caps & remove the metering rod piston/rod assys & put something under the spring(s) to block them up then replace the assys & take her out for a spin & you'll be on the "power" step which is way richer
Re: Troubleshooting temp issue [Re: RapidRobert] #1544176
12/07/13 03:13 PM
12/07/13 03:13 PM
Sacramento, CA
Sacramento, CA
I'll take a look and see if I can visualize what you're talking about a bit better. Not sure what "something" would be that would be appropriate to put under the springs to block them up .. .i'll see ..
Re: Troubleshooting temp issue [Re: cal_gecko] #1544177
12/07/13 03:58 PM
12/07/13 03:58 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yes I would push that Fan in another 1/2 inch also but not the problem you are describing.
Question is that a 2 row radiator or 3??
Ron
Re: Troubleshooting temp issue [Re: RJS] #1544178
12/07/13 05:16 PM
12/07/13 05:16 PM
Sacramento, CA
Sacramento, CA
did a little more digging today.. removed the thermostat and ran it ... saw no water movement in the top of the radiator. Here's a shot of the inside.. I'm guessing this is my problem
Re: Troubleshooting temp issue [Re: cal_gecko] #1544179
12/07/13 05:22 PM
12/07/13 05:22 PM
, now we know
Re: Troubleshooting temp issue [Re: cal_gecko] #1544180
12/07/13 06:01 PM
12/07/13 06:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Never mind, wow ...I guess you don't look in there much?
Page 2 of 4 1 2 3 4
