This compressor has been in place since the early 80s. The air line is 1/2' ridged copper water pipe, most of it is. There is some soft copper that was bent with tubing tool, nothing wrong with soft copper tubing or STEEL either. Galvanized steel pipe is really nice also. Properly setup like my system steel, even black iron won't rust much and what little rust will be taken care of by your drops,filters and water separators.
The key is to run your air line straight up from the compressor with a drain cock at the bottom and use metal line so the air can cool before getting to a water separator. It serves a 4 bay garage and runs over head to the other bays and then drops back down. The horizontal line that runs across the ceiling slopes back to the compressor. So 95% or the water runs back to the first drain cock/leg right next to my compressor.
I have done lot's of spray paint work in this shop and have no water at all in my hoses.
Drain cock/valve at the bottom, it catches 95% of the water right here. I drain it and the tank a few times a month and it's used at least 5 days a week.
Here is the drop that I run my air tools and spray gun off of. There is hardly any water that makes this far. The drop with a petcock get's a little and the air dryer get's almost none. That custom bent soft copper line goes overhead to a hose reel. Water won't go uphill.
This drop is farthest away from the compressor and is tank pressure(175psi) for filling tires, it see's hardly no water at all, I swear because it all falls out before getting this far.
My home compressor is not setup this nice, I am going to use a 60' length of 1/2" OD coiled soft copper line to cool the air and then go to a drop from the ceiling in my little 2 car garage after using it for 25+ years like it is. It does have some water in it sometimes, I do very little painting at home. But someday's there's way too much water coming out of my air at home and it's been on my to do list for years now.
My air hose is always laying out in the driveway for immediate use, I never turn off my compressor at home. Not smart I know but it don't leak.
