Fusible links #1543031
12/03/13 01:56 AM
12/03/13 01:56 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
I want to replace my fusible link, where can I purchase a new one that looks original.
All the ones I see are just wire without the flag.
Also not sure what size fuse is needed for. 70 E body.
This is the fuse off the battery to the relay.
AAR cuda 71 rag challenger
Re: Fusible links [Re: 3406pac] #1543032
12/03/13 02:03 AM
12/03/13 02:03 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Go to your auto parts store ask for a Dorman 85627 Fusible Link...
Just install the proper terminals..
Just my $0.05...
Re: Fusible links [Re: Sinitro] #1543033
12/03/13 02:08 AM
12/03/13 02:08 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
I was looking at that exact one when you chimed in.
Just wasn't sure if the originals were red.
And if that is the proper gauge.
Re: Fusible links [Re: 3406pac] #1543034
12/03/13 02:15 AM
12/03/13 02:15 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Just found this on closeout @ Rock Auto..
http://www.rockauto.com/catalog/raframecatalog.php?catalog=42&partnum=85627
Just my $0.05...
Re: Fusible links [Re: Sinitro] #1543035
12/03/13 02:20 AM
12/03/13 02:20 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Oreillys had them for $2.50.
That will work till I can verify original color.
