Re: MOD MAN INTAKE 440
[Re: AndyF]
#1542889
12/02/13 10:36 PM
12/02/13 10:36 PM
Posts: 2,468 Sydney,Australia
tex013
Sydney,Australia
I have a dual quad one . my thoughts after dyno , street and strip . more suited to a stroker motor for best results . Adding 4 hole spacers and manifold inserts helped . Lost out down low,60', at the strip , made same peak power/mph . Though this was on my old heads , may be different on current heads .Drove fine on the street .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1542890
12/02/13 10:50 PM
12/02/13 10:50 PM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
I run an 800 AVS on a Modman on a G3 6.1 Hemi.
Ive had significant issues with launches...just couldnt tune the lean bog out...even with drilling the pump shooter.
Air door tension made no difference - it would stall no matter what.
So I trialled an 850 Holley dumble pumper on Sat....bog disappeared completely.
Since then other guys have told me that the Modman combined with big head port runners needs BIG fuel at launch .
Otherwise Ive found the Modman to be very responsive off rolling starts.
I thin Tex is right...its probably ideally suited to a stroker or dual carbs.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
[Re: Moparmal]
#1542891
12/02/13 11:12 PM
12/02/13 11:12 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
LOL I thought you'd never run a holley carb??
[Re: runner12]
#1542892
12/02/13 11:14 PM
12/02/13 11:14 PM
goldmember
Gainesville,FL
Looking for some feed back on MOD MAN INTAKES goob bad im thinking if a six pack style is anyone has some info thanks !!
We run one on a NSS car and it's ok up top,but nothing we couldn't kill with a good single carb combo.
[Re: goldmember]
#1542893
12/03/13 12:39 AM
12/03/13 12:39 AM
Posts: 1,443 Maryland
Dads426
Maryland
There is a guy at Capitol Raceway that runs the "Street Cleaner" Super Bee. I know he likes 6-pack setups and when he switched to the mod manifold he picked up a few tenths. Don't know his name, but you may be able to contact him via the A12 registry: A12 Registry
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: goldmember]
#1542894
12/03/13 07:30 AM
12/03/13 07:30 AM
Moparmal
Im not....used for diagnostic purposes only...
Ill be going dual 500 Carters as soon as I have the coin.....
Care to donate to the "keep Mal's car a Holley free zone" fund?
[Re: oldschoolracer]
#1542897
12/03/13 01:38 PM
12/03/13 01:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
had one on a small block stroker with 2 4 barrels. change to M1 and 950 carb ran 4 tenths faster.
Like ALL things in a engine... they(the parts) need to be size accordingly to match the total package... with the intake volume it might be way to big for a stock size engine as was mentioned already
[Re: DoubleD]
#2566746
10/20/18 01:13 AM
10/20/18 01:13 AM
Posts: 435 New Mexico
Scott440
New Mexico
All I can say it is fun with a four speed! Did it eliminate the need for "bars" normally at the front/rear of the intake valley tray?
[Re: Scott440]
#2567792
10/22/18 01:02 PM
10/22/18 01:02 PM
Posts: 1,134 OHIO THE HEART OF IT ALL
64hemi330sedan
I have andy f's old intake on my car. inline two fours with two 750 edelbrocks.I have been in the nine eighty's at 136 mph. with a 55 over rb near 14-1 compression,ported -1 heads and a 715-715 roller cam.I have yet to mess with the tune up yet. it has a slight stumble at the hit. the sixty foot numbers seem a little off for the et's also. its been crappy here and have not been back out to mess with the tune up. all in all I'm pretty happy with the intake.
