383 stroker #1542329
12/01/13 03:19 PM
12/01/13 03:19 PM
Hamiltucky
RBDuster Offline OP
RBDuster  Offline OP
Hamiltucky
I have a 383 block and looking at some stroker combos for my next build. My current combo is a 470 that has ran a best of 5.73 in the 1/8th so I do like the 3.9 crank. I am looking at the following:
1. 3.90 stroke, 6.700 rod and 4.310 piston for 456 c.i.
2. 4.25 stroke, 6.535 rod and 4.310 piston for 496 c.i.
Heads and cam are Indy SR's with a mild port, cam is 661 lift in and ex, duration is 275 at .050. This is what is currently on my 470.
Reason for the 383 is I have one and they are readily available.
Car weighs 2500 with driver and has a powerglide trans. This will be a back up shortblock for 2014 and will be used for the 2015 season.
Anybody running these combo's?
Re: 383 stroker [Re: RBDuster] #1542330
12/01/13 07:21 PM
12/01/13 07:21 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Did something fail in your current 470? Will 26 more cubes (496ci) really make the car quicker enough to justify cost?
Re: 383 stroker [Re: RBDuster] #1542331
12/01/13 07:33 PM
12/01/13 07:33 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have 2 383 blocks and one is going to be a stroker for my next engine.I am looking at 484-496 cid.I would go with the 496 as your parts will support that size of a engine.
Nautilus Racing-
