Best ignition box/coil for stock 400?
#1542287
12/01/13 02:03 PM
12/01/13 02:03 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
The car is a driver 1975 Cordoba. The engine is the stock 400 4bbl, and will remain stock. Just looking for the best reliable ignition system using the stock distributor. The parts store replacement box on the car when I bought it, is junk. Combo's I have been considering: MP orange box with MSD blaster coil FBO box and coil Pertronix ignitor and coil What has worked for you on a stock engine? Thanks Dave
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
Re: Best ignition box/coil for stock 400?
[Re: D149]
#1542288
12/01/13 02:35 PM
12/01/13 02:35 PM
RapidRobert
4 terminal (dual) ballast/5 pin OE system I'm assuming. I'd get a parts house replacement 4 pin ECU & another one for a spare & you'll be fine for your app. My dd 318 starts instantly in warm weather & within a split second in cold weather (Eddie 1406 600) with that setup. With the "dual" ballast & a 4 pin ECU or the replacement 5 pin ones & the 5th pin is a dummy you can add another loop of wire across the ballast on the other end so there is a loop like the OE blue loop of wire on the upstream end to make the ballast a parallel circuit for a hotter spark. As you know (ign) power & reliability are inversely proportional (to some extent) so always carry a spare (ECU/coil/ballast). EDIT I reread your post & I would just get another ECU (plus a spare). The last 2 choices you mentioned would be pricey & in a stock app you would not see a gain from them & the first choice I absolutely would not purchase an orange box. If you dont mind me sayin just k.i.s.s. as you just had a normal part failure & another one will be the fastest/cheapest solution
[Re: RapidRobert]
#1542290
12/01/13 10:13 PM
12/01/13 10:13 PM
D149
Ontario, Canada
I forgot to say that I have several "older" MP orange box's (not the China ones).
I'm thinking orange box with the blaster coil (and ballast) and Pertronix 7mm wires.
