Distributor Id ?? #1542279
12/01/13 01:58 PM
12/01/13 01:58 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
How can i find what year Distributor i have. I know it is a single point for a smallblock. Thanks
Re: Distributor Id ?? [Re: bobs69] #1542280
12/01/13 02:48 PM
12/01/13 02:48 PM
Not sure if there would be a small cast in 2 digit clocking number somewhere on the dist body or not. I'm assuming the bolt on tag is missing
Re: Distributor Id ?? [Re: bobs69] #1542281
12/01/13 08:29 PM
12/01/13 08:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
There is more to distributor ID than what year it is , there are a number of distributor configurations depending on transmission and application.
Look for a part number either on a tag or stamped on the housing .
