Re: Aluminium fuel line pressure?
[Re: SLOW67]
#1542265
12/02/13 01:31 PM
12/02/13 01:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
So stainless will be ok? I really don't care if it's hard to work with, I will have minimal bends anyway until I get to the engine bay area. Another question...What kind of tubing does it need to be shielded with in the bellhousing area?
If I remember right its a 1/8" wall steel tubing to protect the fuel line(any fuel line) in the bell housing area to be legal
[Re: SLOW67]
#1542267
12/02/13 01:40 PM
12/02/13 01:40 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Stainless is what caused me to roll my Daytona on its roof. As a Millwright I hand bent stainless lines 2-3 times a week. I thought this would make a nice, clean install for the oil lines running to my remote oil filter. Well it was and did a nice job till one broke at the farrel on a quick 16 pass sending my Daytona sideways and onto its roof. Harmonics never entered my mind and after about 5 years ended up cracking the brittle stainless line. I bought three cars over the years with aluminum fuel line and that was one of the first upgrades I did was changing it over the GOOD fuel lines. There are lots of good suggestions in the earlier posts but if possible PLEASE stay away from aluminum or stainless.
[Re: SLOW67]
#1542268
12/02/13 01:42 PM
12/02/13 01:42 PM
MR_P_BODY
Cool I've got some old roll cage tubing that should work then. Can the fuel line come up inside the engine bay or does it have to be outside the rail and come in?
This is just the way I do it... I run down the frame rail on the inside then around the rail near the A-pillar zone and up into the wheel housing and go through the inner fender and mount the regulator at that point... then to the carb
[Re: MR_P_BODY]
#1542269
12/02/13 02:11 PM
12/02/13 02:11 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I have done stainless lines on multiple street/strip cars. One was a daily driver with 15K miles on it before I redid the fuel system, another was a fair weather car with 20K+ miles over 10 years, trips out the PA pike to Carslisle, etc. no signs of fatigue. There are tube to AN adapters that make converting the lines clean and simple.
With any metal lines, you have to mind vibration. I just use Adel style cushioned clamps, or scetions of hose to isolate the line. It is also very easy to get carried away while tightening ferrules (Swagelok says 1.25 turns from finger tight as a guideline for most sizes) I have also used brass fittings/ferrules in the past on stainless lines. Sometimes the threads on the stainless fittings have a tency to gall when gasoline is involved, also, the brass is softer so the ferrules won't dig into the tubing as much (with SS lines and fittings, it is go to a couple thousand PSI, so there is some room to work with.)
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#1542270
12/02/13 02:59 PM
12/02/13 02:59 PM
dartman366
Mt. Vernon, Ohio
The 1.25 turn guideline is for setting the furrel to the line during the cinching of the ring's and nut,once cinched then it don't take anywhere that much of a turn to tighten from finger tight.
[Re: pittsburghracer]
#1542272
12/02/13 03:55 PM
12/02/13 03:55 PM
dartman366
Mt. Vernon, Ohio
One thing to keep in mind when you go on a forum to get suggestions. Some cars are raced weekly, some are raced one or two times a year, some are show queens, and some are unfinished projects or just sit in the shop being used as a workbench. Heck some of these guys could us bamboo shoots for fuel line and it would hold up. Keep that in mind when you make your choice.
Ain't that the truth, no more than I have been out in the last two years I would probably be in the bamboo shoot class.
[Re: OUTLAWD]
#1542273
12/03/13 12:40 AM
12/03/13 12:40 AM
Posts: 928 NC
SLOW67
NC
I have seen these hard tube compression to AN too and thats what I figured I use to make up the ends.
[Re: OUTLAWD]
#1542274
12/03/13 09:07 AM
12/03/13 09:07 AM
Challenger 1
Cincinnati, Ohio
You DON'T use ferrules, you use flares in all cases for something as important as fuel lines!
Ferrules will leak eventually just like aluminum line will.
