73 Charger LCA's. Interchange? same as?..... #1541763
11/30/13 10:25 AM
11/30/13 10:25 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Looking for 73 Charger lower control arms for a circle track project. What other cars are the same? Cordoba?
Re: 73 Charger LCA's. Interchange? same as?..... [Re: brads70] #1541764
11/30/13 10:38 AM
11/30/13 10:38 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
No, they use the transverse bars like a Volare (I think)
"I think its got a hemi"
Re: 73 Charger LCA's. Interchange? same as?..... [Re: brads70] #1541765
11/30/13 11:35 AM
11/30/13 11:35 AM
Asheboro, NC Piedmont Triad
Quapman Offline
Quapman  Offline
Yes, all B-bodies through 79? should be the same. Transverse torsion didn't come about until the boxy Dobas.
You working on a 73 Charger, Brad?
Re: 73 Charger LCA's. Interchange? same as?..... [Re: Quapman] #1541766
11/30/13 12:10 PM
11/30/13 12:10 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
71, and 72 are different than 73-74.They changed when they went to the iso mount K frame.
Re: 73 Charger LCA's. Interchange? same as?..... [Re: Quapman] #1541767
11/30/13 12:25 PM
11/30/13 12:25 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Hi Steve
No working on a 73 Cuda circle track car. Using these LCA to increase the track width. Need some spares.
Re: 73 Charger LCA's. Interchange? same as?..... [Re: brads70] #1541768
11/30/13 12:30 PM
11/30/13 12:30 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Well I guess that's not entirely true.... Same set up is in the Charger too...... this car will be a back up car too heavy now.
Re: 73 Charger LCA's. Interchange? same as?..... [Re: brads70] #1541769
11/30/13 09:30 PM
11/30/13 09:30 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
all 73-79 B-bodies (Charger, Cordoba, Magnum, etc.) and all 79-81 R-bodies (St. Regis, etc.)
btw cool cars.
1971 Challenger
