How did U center the steering shaft inside the column? #1541698
11/29/13 10:57 PM
11/29/13 10:57 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Hey guys,
Just wondering out loud here but...
For those of you who have rebuilt your own steering column(s)
What did you use for the centering tool?
In the service manual, it calls for centering tool Miller C-4134
(which is impossible to find).
So, given the unavailability of this tool,
How do you guys center the steering shaft
inside the housing so it doesn't look or end up
off center when installed in the car?
If you've done this job, you've no doubt dealt with
this issue...
What did you end up doing?
Please chime in....
Thanks!
Re: How did U center the steering shaft inside the column? [Re: OLD318] #1541699
11/30/13 03:56 AM
11/30/13 03:56 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
What kind of car is this for?
On my 68 Body column the shafts have only one way to go, there is a keyed area for the steering wheel and the center shaft is a double D ..
Re: How did U center the steering shaft inside the column? [Re: OLD318] #1541700
11/30/13 04:10 PM
11/30/13 04:10 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
with the steering shaft(coupler) mounted to the st,box,i moved the plate on the inside of the firewall(while turning the steeringwheel) until i was satisfied,feeling with my finger and eyeballing the space between the inner shaft and the lockouttube (70 E).
Re: How did U center the steering shaft inside the column? [Re: sthemi] #1541701
11/30/13 11:00 PM
11/30/13 11:00 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
The steering column is for a 70 B Body (Coronet).
Re: How did U center the steering shaft inside the column? [Re: OLD318] #1541702
12/01/13 02:29 AM
12/01/13 02:29 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Assuming your referring to the keeping the steering shaft centered in the tube during installation, I cut 3 wedges (plastic or hard wood) placing them in 3 equal spaces, snugged between the shaft and tube during tightening of the firewall plates
Re: How did U center the steering shaft inside the column? [Re: AAR#2] #1541703
12/01/13 01:19 PM
12/01/13 01:19 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Its been a while but there's a bearing toward the steering wheel that keeps the shaft straight by the wheel, and then there's a plastic bearing at the end of the housing that centers the tube. when its mounted to the steering box it usually centers itself in the tube.
I did take a piece of foam (from the heater box piping) and slid it into the tube over the shaft. I pushed it in far enough to be flush but keep dirt out.
Hope that helps.
Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
