Re: big block rocker shaft wear?
[Re: idriveagremlin]
#1541369
11/29/13 01:46 PM
11/29/13 01:46 PM
Posts: 1,505 TN
SCATPACK 1
TN
Just curious, What oil were you running with these rocker arms? Since the PRW Rockers are not rollerized, you need oil that has a really high Zinc content. I had the same problem with a set of the iron Isky rocker arms. Kept galling the rocker shaft up. Finally went to a hardened shaft and changed over to Valvoline racing oil which is the highest Zink content you can get now. Just a thought, but I would at least change the rocker shafts or you are going to experience the same thing again. Good Luck
Old Geezer Racing
[Re: StealthWedge67]
#1541372
11/29/13 06:00 PM
11/29/13 06:00 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Am I not thinking straight here? Those shafts look like the oiling holes are in-line with the bolt holes (???). I think the shafts I have worked with have all had the oiling holes straight down when bolted up (not aligned with boltholes). This is why there is a right and wrong way to have them installed.
I asked that question as well. If you look close, it appears there is a wear mark where the bolts go down thru down as well.
If those rockers he is using don't have bearings on them, then they aren't round because I would think there would be a wear pattern all the way across, not were it appears the bearings are riding, so I think the shafts aren't hard enough for those type of rockers.
But, never got an answer if both sides are the same or just the one side.
[Re: Blues_Cuda]
#1541375
11/30/13 10:08 AM
11/30/13 10:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Your car? This is @ Gateway Motorsports Park during Drag Week.
That 52 Ford PU is my buddies that I rode with during DW... nice ride.. it runs 11.50 on motor(no roll bar)
