'83 D-150 tank sending unit #1541299
11/28/13 09:54 PM
11/28/13 09:54 PM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
Does anyone make a replacement? Van's lists just about everything but...
Thanks!
Re: '83 D-150 tank sending unit [Re: slantzilla] #1541300
11/28/13 10:32 PM
11/28/13 10:32 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I don't think they are reproduced anymore. There was a batch made a few years back, you sometimes see them pop up on Ebay or the dealer might be able to get them still. Like all the others the sender isn't accurate though. They go for about $150-$180
Re: '83 D-150 tank sending unit [Re: 440newport] #1541301
11/29/13 09:53 AM
11/29/13 09:53 AM
Park Forest, IL
Park Forest, IL
That's what I was afraid of.
Thanks for the info.
I have found a place that rebuilds them. Maybe I'll go that route when I get that far.
Re: '83 D-150 tank sending unit [Re: slantzilla] #1541302
11/29/13 10:00 AM
11/29/13 10:00 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
When I replaced the one in my 84 Ram Charger it was the last of 2 in the US.My buddy is a parts man at dealer and found it.It was around 65 bucks my cost thru the shop at the time.That was at least 15 years ago.Rocky
Chrysler Firepower
Re: '83 D-150 tank sending unit [Re: therocks] #1541303
11/29/13 01:04 PM
11/29/13 01:04 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
NOS senders for the 80's models are $200+ on Ebay when you can find them.
I have in the past used a Wema tank sender & had my IT friend solder a diode or resister or something in the line to make it or you can do what I do now when I use them which is taking a fuel gauge apart & refitting it into the stock cluster
Wema makes them whatever length you need & you won't need another one ever again
Re: '83 D-150 tank sending unit [Re: BulletBob] #1541304
11/30/13 04:07 AM
11/30/13 04:07 AM
Park Forest, IL
Park Forest, IL
After laying under this thing doing a trans swap, I'm kinda leaning toward putting a cell in it anyway. This thing will eventually be a hot rod toy, and the driveshaft that close to a plastic tank makes me nervous.
Re: '83 D-150 tank sending unit [Re: slantzilla] #1541305
11/30/13 11:30 AM
11/30/13 11:30 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have cut one of those tanks like a roll of bologna with a driveshaft before & got lucky
My rear shaft twisted in half at a red light
Re: '83 D-150 tank sending unit [Re: slantzilla] #1541306
11/30/13 01:50 PM
11/30/13 01:50 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
That's what I did; replaced the plastic tank with a cell in the bed and I was able to run 3" dual exhausts down both sides with the tank out. I eventually will be putting some kind of cover on the bed to hide/protect the cell.
Re: '83 D-150 tank sending unit [Re: Hemi_Ram] #1541307
11/30/13 01:52 PM
11/30/13 01:52 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
pix of 20 Gal cell
Re: '83 D-150 tank sending unit [Re: slantzilla] #1541308
12/01/13 12:54 AM
12/01/13 12:54 AM
PA USA
ScatPakWarehouse Offline
Good Guy Alert
Good Guy Alert
PA USA
I have a few NOS ones 1976-87 how many gallons is your tank these all are Dealer Parts Dept. pulled
Mopar Parts Hoarder ... Still Crazy after all these years.
Re: '83 D-150 tank sending unit [Re: slantzilla] #1541309
12/01/13 04:38 AM
12/01/13 04:38 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
any way to make the earlier model work? is the mounting ring the only difference? if so, might be just as easy to swap the mount, from an older tank onto yours. or, just swap to an 80 or earlier tank. those sending units are pretty common.
Re: '83 D-150 tank sending unit [Re: Golden-Arm] #1541310
12/01/13 11:13 AM
12/01/13 11:13 AM
PA USA
Good Guy Alert
Good Guy Alert
PA USA
Have about 6 of them they are all diff. looking also part #'s not all the same just saying
Re: '83 D-150 tank sending unit [Re: ScatPakWarehouse] #1541311
12/01/13 07:37 PM
12/01/13 07:37 PM
Park Forest, IL
Park Forest, IL
I believe it is a 22.
Re: '83 D-150 tank sending unit [Re: slantzilla] #1541312
12/05/13 11:44 PM
12/05/13 11:44 PM
PA USA
Good Guy Alert
Good Guy Alert
PA USA
Just sold a 36 gal. 1 today you have a part # for that 22 gal ?
Re: '83 D-150 tank sending unit [Re: BulletBob] #1541313
12/11/13 10:32 PM
12/11/13 10:32 PM
Rio Linda, CA
N
nytemuvr Offline
nytemuvr  Offline
N
Rio Linda, CA
Isn't it amazing that a driveshaft would break sitting at a red light...
1972 Challenger 340(original owner) 1968 D100 1997 HD Road King
Re: '83 D-150 tank sending unit [Re: nytemuvr] #1541314
12/12/13 08:43 PM
12/12/13 08:43 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Not at the light but about six foot out where the tires finally bit
It got a fuel cell after that
It ran 7.40's in the 1/8 street driving everyday with a stock tank
