Balancers #154122
11/20/08 04:47 PM
11/20/08 04:47 PM
Canada
N
NiceFishEh Offline OP
N
Canada
On a 1970 340, assuming it has a steel crank, will a cast crank balancer fit on it?
Re: Balancers [Re: NiceFishEh] #154123
11/20/08 04:50 PM
11/20/08 04:50 PM
ya it will fit. wont work, but it will fit
Re: Balancers #154124
11/20/08 05:00 PM
11/20/08 05:00 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
what he said , if you want to ruin that engine running it out of balance then throw on an external balance balancer .
Re: Balancers [Re: JohnRR] #154125
11/20/08 07:17 PM
11/20/08 07:17 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The early 340s were internally balanced and need a neutral balance balancer. The cast crank engines were eternally balanced and the balancers, while they will physically fit, are not inter changable.
Re: Balancers [Re: 69Cuda340S] #154126
11/21/08 09:32 AM
11/21/08 09:32 AM
Canada
N
N
Canada
Reason I ask... it runs as smooth as possible with no vibration. I'm trying to avoid pulling the pan to verify if in fact it does have a steel crank. My guess it does. At about 3k it has a slight hum like a clutch fan would make. I'm told that's normal on 340's???
If I do replace the balancer with the proper one, will it affect the engine since it has been worn with the external balancer for at least the 5 years I've owned the car.
Re: Balancers [Re: NiceFishEh] #154127
11/21/08 10:44 AM
11/21/08 10:44 AM
i wouldnt replace anything without knowing whats in there
Re: Balancers #154128
11/21/08 10:48 AM
11/21/08 10:48 AM
JohnRR Offline
JohnRR  Offline
Re: Balancers [Re: JohnRR] #154129
11/21/08 11:32 AM
11/21/08 11:32 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If it ain't broke don't fix it. After 5 years Leave well enough alone.
Re: Balancers [Re: MoparforLife] #154130
11/21/08 11:44 AM
11/21/08 11:44 AM
Canada
N
N
Canada
Thanks guys
Think I'll just throw another log on the fire!
