HELP!!!.. Remote start acting up.....2006 w. Cummins #1540483
11/27/13 09:30 AM
11/27/13 09:30 AM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
I installed the MoPar remote start kit several years ago and it has worked just fine, but in the most recent attempts to start it the engine will run for about 3 seconds and then shut down...or it will crank and not fire up at all. The heater blower and dash/tail lights remain on. What gives??
thanks for any help!!!
Re: HELP!!!.. Remote start acting up.....2006 w. Cummins [Re: jughed] #1540484
11/27/13 10:17 AM
11/27/13 10:17 AM
Lehigh Acres, Florida
rickstershemi Offline
Sumpins Brokeded......
Rickster
Re: HELP!!!.. Remote start acting up.....2006 w. Cummins [Re: rickstershemi] #1540485
11/27/13 10:22 AM
11/27/13 10:22 AM
In The Hills
jughed Offline OP
jughed  Offline OP
In The Hills
hmmm...it worked fine this morning..... ....
Re: HELP!!!.. Remote start acting up.....2006 w. Cummins [Re: jughed] #1540486
11/27/13 10:47 AM
11/27/13 10:47 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
got fresh batteries in the remote? cheap and easiest thing to check.
Re: HELP!!!.. Remote start acting up.....2006 w. Cummins [Re: Golden-Arm] #1540487
11/30/13 03:36 AM
11/30/13 03:36 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Same thing happened in my Chevy Diesel two years ago. Ended up putting a new brain box in under warranty. It was an aftermarket unit. Now it shuts off after ten minutes rather than thirty.
